Inner fairing question
Old Mar 1, 2014 | 10:20 PM
peteperrone's Avatar
peteperrone
Question Inner fairing question
So I have to replace my inner fairing on my '11 FLHTC. Found a good deal on an earlier (97-07) inner fairing that has the opening for the throttle cable. Any suggestions on what to do/how to plug the opening?
Thanks for any advice!
P
Old Mar 1, 2014 | 11:03 PM
SpiderPig's Avatar
SpiderPig
Don't have a recommendation for filling the hole. Just want to make you aware that the deflectors have a different bolt pattern.
Old Mar 1, 2014 | 11:12 PM
peteperrone
Not following? What deflectors.
Old Mar 1, 2014 | 11:29 PM
senna's Avatar
senna
When the previous owner put a color matched inner fairing on my 09 they put the earlier model on. I never even notice the hole unless I am working on it.
Old Mar 2, 2014 | 08:26 AM
SpiderPig's Avatar
SpiderPig
The plastic air deflectors that are bolted under the right and left side. On the older version (pre) 09 they have a 3 bolt pattern that they attach to. On the newer version 09 and up it is a 4 bolt pattern. If you are not planning on using the ones from your 09 you are OK. Or just install pre 09 air deflectors.....
Old Mar 3, 2014 | 04:04 PM
peteperrone
Thanks Spiderpig,
I actually scored at the Webster West Side Motorcycle Swap meet (first Monday of the month). Got an inner fairing, engine guard, and inner fairing mirrors for $190! If I had purchased on eBay would've been $300+
Engine guard and fairing are on (mostly). Missing the spacer and nut for the left mirror and need to get a new spring clip retainer for the clutch pin.
Outer fairing cosmetically messed up but structurally good. Quick fix will be a bra to cover it for now.
P
UltraClassicElectraGlide
Jun 2, 2013 02:31 AM
UltraNutZ
Audio Systems
Feb 25, 2013 08:23 AM
nomad
May 30, 2010 11:14 AM
jimsflh
Feb 9, 2010 03:46 PM
Hanoverfiste
Sep 4, 2008 06:58 AM
