Wind deflectors
Old Mar 8, 2014 | 02:02 PM
ZenGlide's Avatar
ZenGlide
Originally Posted by SafetyMan
I had the ash tray and gave it away.... too embarrassed to sell it.
Not worth a hoot, IMHO.
From my experience, the between the fork ash tray deflector offered the most bang for the buck of any of my buffeting/wind suppression mods. Well worth the $25 and five minute install. It made a difference on my UC.
Old Mar 8, 2014 | 05:04 PM
Sparkee...'s Avatar
Sparkee...
I am 6' tall and found the fork deflectors (fangs) worked best for me on my Electra Glide Classic. They probably cut the buffeting down by 95% or more. Some think they are ugly, but I though the newer curved models look good with a bit of a nostalgic look.
I started with the soft lowers and they did nothing for buffeting behind the wind shield. The soft lowers are still worth every penny and are always in my bags. They indispensable when riding in the rain and cold weather keeping the water and cold wind off my arthritic knees.
Old Mar 8, 2014 | 05:19 PM
TMOUT's Avatar
TMOUT
Changed the airflow over the tank behind the 'wing big time.
Old Mar 9, 2014 | 10:03 PM
2002FLSTCI's Avatar
2002FLSTCI
I used the fangs and soft lowers on my Heritage and loved them in the winter. Once it warmed up the lowers came off. I now have an Ultra. I put the ashtray on and it made a huge difference. I am now looking at getting fangs. If they work on the Ultra as well as the Heritage, I will be set.
Old Mar 9, 2014 | 10:14 PM
Griff012FLHX's Avatar
Griff012FLHX
I don't see calling the ashtray ugly, I hardly even notice mine....
Old Mar 10, 2014 | 01:09 AM
Uncle Paul's Avatar
Uncle Paul
Ride your bike at 70 mph.
Put your arm across your chest, and see if the buffeting is reduced.
If it does, that means the buffeting is caused by wind coming up from under and around your tank.
If this is the case, buy and install fork fangs. Takes 5 minutes. Should do the trick for you.
Enjoy the ride.
Old Mar 10, 2014 | 08:46 AM
Uncle Larry's Avatar
Uncle Larry
The Soft Lowers can/will cause excessive engine temperatures if used in moderate to warm temperatures. The Air Baffle does help some ( I've got it on both my dressers ) I do have the "fangs" on my 1992 FLHTCU and they do help but they will contact the lowers on a tight turn ( never caused any damage ) I believe that there is a new design now for the fangs that clears the lowers.
Old Mar 10, 2014 | 09:20 AM
jphii's Avatar
jphii
I didn't get a chance to get either before I left. I rode 718 miles yesterday from NC to Tampa. It was about 45 when I left, and 77 when I got here, and it wasn't as bad as I thought. I think I'm going to pick up a set of the fangs before I head back, just to see what kind if difference they'll make. I think having good riding gear makes a bigger difference.
Old Mar 10, 2014 | 10:06 AM
FASTART's Avatar
FASTART
I installed the ash tray and the fork deflectors , noticed almost all of the buffeting was gone but didnt like the look of the deflectors , I cut 5 1/2 inches off the bottom of the deflectors and powder coated black , still work as good but can hardly notice them
Art
Old Mar 10, 2014 | 10:19 AM
beary's Avatar
beary
Originally Posted by bigheadted
They deflect wind in different areas, there is no real comparison.
Having run both and since you are leaving soon I would do soft lowers. The fork deflectors only take a few minutes to install so you could do both of them.
I agree, it depends what you are trying to fix. If it's cold air on the legs, then soft lowers. If it is the buffeting wind, then the fork deflectors. The triple tree deflector is OK, but doesn't work nearly as well as the fork deflectors.
Beary
