removed the equalizer and the same thing ,, they flash reg. for about three flashes the go to a faster flash,, will this hurt anything?? the faster flash does not bother me,, the red key does not bother me,, as long as it wont hurt or burn out something. whatcha think???
thanks mike
I would check for a pinched lighting wire. Any fuses blown?
not that i can find looked last night,, ohmd all fuses all are good ,, took every thing apart all wires intact and no pinched wires,, see above post for what i also did,, think it will hur anything,, mfg is sending another equlizer to try ,, mabe a defective one ,, hell who knows
Faster flashing and key light on are the only consequences of not using the equalizer. No damage will occur. The EQ shown from eBay is not the Custom Dynamics version and may be missing the circuitry responsible for the key light. It apparently works for the load to control the blinker speed. The CD unit costs more and it connects to the battery too.
if the key stays light up all the time, you have a current TSSM code.
This is it. It could be related to your install, but if the light stays on you have an active code in the TSSM or TSM if you do not have security. The only way to get it to go out is to reset code and fix the problem that is causing the code. Do a code search on the speedo and you will have a better idea on the actual problem
I been reading this string because my 06 Electra Glide red light stays on.
It does show a DTC code of b1121 which is left turn signal module I think.
Took off seat and stared at the bird nest of wires and connectors and undid and redid them all that was behind the battery. Before I did this the light stayed on while running but EVERYTHING worked just fine. NO Problems but the red light. I think it has LED but not sure. It does have a long pink connector that appears to be not stock that feeds two big pin connectors.
I just bought this bike and I have described and done way above my normal abilities. I cleared the code but have not rode the bike since I did all that and before the red light would come on when I engaged a turn signal.
Simple question Should I care about the red light if all works well but it stays on?? Seems to be some feel no biggie and that is fine with me lol.
Thanks for any input as I realize this tread is several months old but you never know.
