No help in Tech forum maybe here?
Old Mar 12, 2014 | 09:39 AM
Whodattom's Avatar
Whodattom
Default No help in Tech forum maybe here?
OK, this is a newbie question. I removed the front wheel to have the tire replaced on my 2010 Street Glide. Followed the instructions in my service manual to re-install. My question is that the spacers on the left fork leg fit flush against the inside of the fork slider. On the right side the spacer on top portion of the fork slider appears to be flush but the lower portion (axle retainer?) is not flush. There is a very small gap.
When I disassembled/reassembled I didn't completely remove the axle retainer and slipped the axle back in, then following the manual I torqued the axle bolt and then tightened and torqued the axle retainer bolts.
Am I missing something or is this normal?
Old Mar 12, 2014 | 10:03 AM
Joe12RK's Avatar
Joe12RK
It's normal. You can loosen the axle retainer and push it towards the spacer while re-tightening it. Joe
Old Mar 12, 2014 | 10:12 AM
Whodattom's Avatar
Whodattom
Default Thanks!
Thanks Joe! 50+ looks in the tech forum and I got crickets.
Old Mar 12, 2014 | 06:31 PM
hardheaded's Avatar
hardheaded
maybe someone else has removed the wheel before and flipped the cap around. i think they fit better one way than the other.
harley_jeff
Jan 20, 2018 04:50 AM
Whodattom
Wheels/Tires
Mar 11, 2014 05:53 PM
chunks
Apr 8, 2012 12:57 PM
gearedforacure
Mar 3, 2012 07:22 PM
sdbiker
Wheels/Tires
Mar 23, 2009 03:28 PM
