Thundermax ECM - any downsides (other than cost?)
I would agree that a ThunderMax is not for everyone and would never say it is the best thing out there but for some of us it was a perfect fit. Since I first initiated mine with a pre-loaded map from Frank at Drago's, I have done nothing but ride. Haven't had it on a dyno but the increase in torque and horsepower is obvious. I regularly check my plug condition and have what I would call consistant coloring that indicates an optimal AFM. On group rides, I am getting better fuel mileage than the others, costing less to fill after the rides.
The map selection is key and I had no input there. Frank knew from experience what was going to work with my cams, pipe, air intake selection for my 103 and hit it right on. It did run a bit rich on initial start-up but after a few rides the wide band O2 sensors relayed real time data to the ThunderMax and auto corrected the AFM. I had no pinging and timing seems to be on the money.
I'm the kind of guy that doesn't mind tinkering but just haven't had the need to.
It kinda makes me wonder sometimes what aftermarket ECM will emerge as the clear cut winner but likely the constantly changing technology will make them all obsolete before long.
Good luck with whatever you choose.
Dyna makes a mounting kit for the PV which allows you to ride, tune and re-write the map as your riding (stopped of course) as it is learning your riding habits.
Great idea.
As eventually there will be very little difference after about 10 flashes over 4 or 5 months.
From what I have learned from their site and guides and videos the Autotune module still learns and autocorrects from the flashed map. this is why you can purge all cached information with the PV after flashing the map into the ECM/ECU. By continually doing this with the PV eventually the bracketing of the information becomes a constant with minimal or no change due to your riding style. this means that the auto tune is only going to change tuning because of atmospheric conditions and not riding styles.
As I said Great idea for the constant reflashing of the ECM/ECU with the PV.
I have the Thundermax as it was the one that I found out about first and research on. I wanted a ECU/ECM replacement as i come form an industry where we try to remove as many points of failure in a system as we can.
An ECU, O2 Sensor are all single points of failure. bu adding the Autotune, PV Stock ECU, O2 Sensor, they are all points of failure but trouble shooting is going to be more difficult.
My Question is.
How much data is kept before over writing in the Thundermax or Auto tune?
how much memory is in the Autotune or thundermax to be used as cached memory?
Is the PV the only unit which caches the Data when connected to the auto tune? If so then to do what was mentioned above you have to ride with the PV all the time to stabilise the MAP flashes for the riding style.
