Rear Brake question
Old Mar 17, 2014 | 12:36 PM
white01ss's Avatar
white01ss
Default Rear Brake question
I posted this question in the Tech forum, but it didn't get any love
I have an 09 ultra w/o abs, the rear brake is soft on the first pump then firms up. I have bled the rear brakes, and I'm still having the issue?
I did bleed the brakes with the bike level and the rear brake reservoir has fluid.
Ideas??
Old Mar 17, 2014 | 12:58 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Was fluid level down when you bled brakes? Did you work on the brake and then had issues or you noticed it was spongy and wanted to bleed brakes. Do you live in very mountainous/hot area ? (Reason I ask is we ran into this problem after riding through desert to Grand Canyon and then up the mountains in Colorado?). When you bled them did air quit coming out or did lever ever get hard ? If level was down check around all banjo fittings for signs of leakage and brake caliper area as well. Sometimes bleeding can take a lot longer then you would think. Also make sure you keep adding fluid and never let reservoir run down to low as you will have to start again.
Old Mar 17, 2014 | 02:41 PM
Joe12RK's Avatar
Joe12RK
warped rotor may push the pads away from the rotor until you press the pedal
Old Mar 17, 2014 | 02:46 PM
Jumpman's Avatar
Jumpman
This.
Old Mar 17, 2014 | 02:50 PM
white01ss's Avatar
white01ss
I live in KS, so it is relatively flat in our area. I bought the bike knowing it had this problem. I put new wheels/rotors on it (which were used off a 2014 SGS), so I don't think the rotor is the issue?? But maybe I need to investigate this further.
Fluid was full the entire time, and never let it run down. I have inspected around the all fittings front to rear and around the reservoir shows no signs of leakage/seeping. That is why it left me scratching my head.
The first pump of the brake is very soft, then the second it fine. If you rotate the back tire 1/4 turn, then the scenario starts over again.
Old Mar 17, 2014 | 03:35 PM
dansflhti's Avatar
dansflhti
I can't add anything to your brake issue,but I'd love to see your 09 with the SGS wheels on her.
Old Mar 17, 2014 | 03:36 PM
collin's Avatar
collin
try pumping it up and gently crack open the banjo bolts, front, then rear sometimes a air bubble is trapped in there.
Old Mar 17, 2014 | 04:03 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Use a mirror, and listen closely. I suspect you'll detect the pads moving in the caliper, which they shouldn't be. That forts push is taking that up.
Warped rotor is a possibility, but don't discount dirty caliper pistons sticking or an unevenly worn pad set.
Old Mar 17, 2014 | 06:01 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Service / Tech | Lyndall Brakes
Could make the difference
Old Mar 17, 2014 | 06:05 PM
grbrown's Avatar
grbrown
Cool
Some good tips above. Bleeding brakes can sometimes be a chore. I recently installed a new calliper and brake line and the darned thing was hard as nails in a few strokes, but on other occasions I have also had problems. The rear caliper and master cylinder are on a similar level and the line is also level, so unlike the front brake, Nature doesn't lend any help.
If the rotor is OK you have air in the system, despite your best efforts. There is a Sticky on bleeding brakes in the Tech Brakes forum, which may help.
