Wondering if fuelmoto CP 10.25 pistons have a front or rear orientation. I know the larger valve reliefs need to be inward facing and are the intake reliefs. Never saw any front or rear arrows like stock slugs and nothing in the cp instructions from what I can see. Anyone?
You are correct. The larger reliefs are for the intake valves. So they go inward towards the carb/throttle body.
So each piston is interchangeable front to rear as long as the large valve reliefs are facing center/each other, right? The pin bores are center and not offset as in the,stock ones. Correct? Just want to be sure.
FYI - I talked with Keith @ FM today just to be sure. CP 10.25 FuelMoto pistons are interchangable front to rear. Obviously the larger valve reliefs are for the larger intake side valves and must be positioned as such. Larger reliefs facing each other toward the center of the motor.
They are the only people I'd trust to answer this question. You can see the different interpretations random internet answers are based upon.
In addition the the intake valve reliefs there is also a cutout on the bottom of the piston skirt for connecting rod clearance that goes to the center also.
