Hello, I just ordered a PCV from fuelmoto. My bike is stock except for SE air cleaner and Supertrapps.
Will the improvement be enough to notice right off the bat?
I do plan future work like head work and cams with headpipe that has O2 sensors to support the addition of the auto tune. It is running pretty lean right now.
Reason: more description
Just by adding a PC-V the difference will be subtle with the right map. The truth is (and the haters will chime in here) that the ECM will adjust to a stage 1 (headers mufflers , and free flowing air cleaner) just fine. Personally I've never seen anyone post that their bike blew up without blowing hundreds of dollars on a tuner.
You plan additional mods so the its an appropriate choice, but I wouldnt expect to be doing wheelies just because you added a PC-V
less heat,stumbling,pinging,surging.increase in throttle response,fuel moto maps tend to be a bit rich so u might lose 1-2 mpg.imo worth the difference.never knew how bad it ran stock till i added the pcv.
