Truck Lit phase 7 problems
Old Mar 20, 2014 | 09:35 AM
Brusier1028's Avatar
Brusier1028
Default Truck Lit phase 7 problems
I've had a truck lite phase 7 since September 2012 and now the led light is starting to flicker and not turn on. Fuzes are good power is there. Is it safe to assume that the led light is failing. Just seems strange that LEDs would stop working so soon. Anyone else have this problem and what did you do to fix it.
Thanks
Old Mar 20, 2014 | 09:48 AM
Nute's Avatar
Nute
Make sure the power supply is constant, uninterrupted 12 Volts. If so I would suggest you return your LED for a exchange. It would appear the one you have is defective.
Old Mar 20, 2014 | 10:07 AM
Hammz's Avatar
Hammz
Make sure the connector at the light is making good contact. Did you use dielectric grease when you assembled it originally.
Old Mar 20, 2014 | 10:12 AM
Brusier1028
Thanks guys.
Yes it is plugged in and there is the correct power reaching the plug. I just got done testing it. I did not use the grease when I first put it in.
Old Mar 20, 2014 | 10:50 AM
rbferg's Avatar
rbferg
Like mentioned, try dielectric grease in the connector. If that doesn't work the Truck-Lite has a 3-Year Warranty.
Old Mar 20, 2014 | 10:57 AM
Brusier1028
Thanks for the tip
Old Mar 20, 2014 | 11:00 AM
EricD10563's Avatar
EricD10563
Are both LED flickering high/low beam if both it sounds like a power source problem, if just one LED is causing the problem then it sounds like a bulb, just an idea.
hdbikerg08
Jun 4, 2016 07:18 PM
star2nv
Dec 17, 2015 06:03 PM
RR611
May 3, 2015 11:08 PM
SpiderPig
Touring Parts
May 4, 2013 05:19 AM
nevada72
Sep 2, 2012 09:42 AM
