Need tech advice..
Old Mar 22, 2014 | 07:34 PM
mdanehart's Avatar
mdanehart
Default Need tech advice..
My 07SG with a 113/ Thundermax/ S&S cams, heads and many other modifications is running somewhat erratic under heavy throttle, spitting or miss issue, I did a dianogistic code check and found nothing.
I am not sure if is fuel related or spark?
Any advice from the experts where to start?
Thanks!
Old Mar 22, 2014 | 08:17 PM
mdanehart's Avatar
mdanehart
For got to mention that the plugs have been swapped out for a new set.
Old Mar 22, 2014 | 10:15 PM
Cruisineasy1's Avatar
Cruisineasy1
I'd check to be sure the cam timing is correct. May be off a tooth or two..
Old Mar 22, 2014 | 10:21 PM
stro1965's Avatar
stro1965
Was it running well before? Is this a new issue and, if so, what changed?
Old Mar 22, 2014 | 10:41 PM
wurk_truk's Avatar
wurk_truk
Have fuel pressure checked.
Old Mar 22, 2014 | 11:00 PM
Cruisineasy1
Good point. May be clogged fuel filter.
Old Mar 22, 2014 | 11:11 PM
hover's Avatar
hover
Check to make sure the spark plug wires are installed correctly if you just changed them.
Old Mar 23, 2014 | 05:06 AM
mdanehart's Avatar
mdanehart
The bike ran excellent until the last tank of fuel that took forever to pump, I assume that it was the bottom of the Sunoco tanks and it was cold and just wanted to get home! I will first explore the fuel filter. Thanks.
Old Mar 23, 2014 | 05:09 AM
srt8's Avatar
srt8
oh crap you just diagnosed your problem right there
Drain that crap out of the tank clean your tank out replace your filter and get some good gas you should be good to go after that
Old Mar 23, 2014 | 07:49 AM
mdanehart's Avatar
mdanehart
Just read over the service manual and watched a YouTube on fuel filter replacement, another interesting adventure.
munkster
Engine Mechanical Topics
May 17, 2019 06:59 PM
pdog75
General Topics/Tech Tips
Nov 6, 2017 09:36 PM
tonebone_79
Jun 7, 2015 08:22 PM
mr1gebby
May 18, 2012 09:41 PM
sporty79
13
Aug 17, 2007 12:15 AM
