Cam and engine help needed.
Old Mar 23, 2014 | 04:28 AM
marvo75's Avatar
marvo75
Default Cam and engine help needed.
My 88 has 40k on her, decided to get a motor kit, thinking on the 98 kit and need to k.ow what cams would work best? And any other advice towards what to go with in general...appreciate any advice.
Old Mar 23, 2014 | 06:35 AM
sporacer's Avatar
sporacer
We need to know what compression ratio and if your doing head work? What are you wanting out of your build and how much do you have to spend?
Old Mar 23, 2014 | 06:38 AM
grbrown's Avatar
grbrown
This is a big subject! Any tuning shop that provides a big bore kit should also be able to advise on a matching cam and head work. My advice is either contact one of the HDF sponsors or look up a local shop. You will get good results with a proven tuning package from a reputable shop. Hillside and FM are both HDF sponsors, but there may be more.
Old Mar 23, 2014 | 07:09 AM
2010 ultra man's Avatar
2010 ultra man
Default cams
I tried several different cam sets in different engines. Some give power early, some middle and some late.Consult a reputable shop (as previously stated) and tell them how you want to ride.They should be able to help you with the whole build plan.You can call Bobby Wood at Wood performance. He is the "wizard" in my opinion. http://www.woodcarbs.com/cams.htm. Good luck!
Old Mar 23, 2014 | 07:20 AM
just plain john's Avatar
just plain john
Where do you spend most of your time in the RPM range? I rarely exceed 4K so I picked a cam that comes on early but is done by 4800. I personally don't know anyone that runs a cam that goes to 5500 or more. It's all about the combo, don't over cam.
Old Mar 23, 2014 | 08:44 AM
micalaut's Avatar
micalaut
As stated, decide your riding style and RPM range, lots of cams out there that do similar things. If your like most you will want a cam that has lots of low end and mid range. Important thing is to match c/r to the cam you pick. Get some mild head work done and you will like it. A 98" with a cam like an Andrews 26, c/r at 9.6, a good tune and should impress you.
Old Mar 23, 2014 | 08:51 AM
0ldhippie's Avatar
0ldhippie
All good stuff. Ya need to decide what your goal is before ya can pick a proper bore/piston/head/cam/tune combo to achieve it.
Old Mar 23, 2014 | 11:04 AM
marvo75's Avatar
marvo75
I would say bottom end mid for cam, and what does get some head work consist of?
Old Mar 23, 2014 | 11:35 AM
grbrown's Avatar
grbrown
Thumbs up
There are several variables when upgrading an engine. In addition to more cubic inches a change of CR and cam are quite obvious, but some combinations will give of their best with reworked heads, meaning reprofiled or enlarged ports, even bigger valves. We have access to some of the old and trusty cam profiles that have been around since Evo days, but there are also recent designs that can give truly impressive performance improvements.
Now we have got you on the hook, it really is worth phoning someone like Hillside, to get the lowdown on the choices available to you! There is no substitute for learning from the experts! We're just customers in here, like you may be soon......
Old Mar 23, 2014 | 05:31 PM
marvo75's Avatar
marvo75
Appreciate the advice, ill make a few calls tomorrow.
CaptainK
Jul 1, 2011 12:22 AM
PFWiz
Sep 29, 2010 05:00 PM
1bagman
Aug 13, 2010 02:21 PM
AFHuey
Exhaust System Topics
34
Jun 26, 2010 10:09 PM
expolice
Oct 9, 2008 08:06 AM
