Power Commander 5 slow starting.
Old Mar 24, 2014 | 04:45 PM
mllgator's Avatar
mllgator
Try starting while your bike is in Neutral.
Old Mar 24, 2014 | 05:44 PM
Newfie4Life's Avatar
Newfie4Life
6th Gear
Had Power Commander tech run me through turning of all diagnostics and anything else that may be an issue. Also firmware is up to date. It's just crazy that Power Commander has not addressed this in their firmware, if this is at all possible.
Old Mar 24, 2014 | 05:54 PM
Chiledog's Avatar
Chiledog
Cool
Dang! That never occurred to me... Does the Run switch have to be on to start?
Old Mar 24, 2014 | 06:20 PM
MikeTD3's Avatar
MikeTD3
Just hit the start button right after flipping the switch and it should fire right up. If you wait, the PCV powers down and has to power back up when you start cranking....hence the delay.
Old Mar 24, 2014 | 06:46 PM
trip20's Avatar
trip20
Yup.
That's how my PCIII behaved on my last bike. I stopped waiting for engine light to turn off and that solved my hard starts.
Old Mar 24, 2014 | 06:49 PM
Newfie4Life
6th Gear
Tried that. Only works every now and then. It's hit or miss.
Old Mar 24, 2014 | 06:50 PM
Bachus's Avatar
Bachus
Don' Know!
02FLHPI w/retro fit PCV from F/M w/Autotune. Hit the start button and you can not get off quick enough! Fires immediately! Doesn't make any difference if fired now or waiting on light to go out.
09FLHTP w/PCV from F/M, Stage one, spins 3-5 times and fires up. Added cams, new map from F/M, same thing. Not bad, just wondering what is the difference.
I'm thinking, compression releases on the 103 want to get it spinning before firing.
Asked this question to F/M, they said to fire upon turning on ignition. Makes no difference.
Dan B.
Central Ks.
Old Mar 24, 2014 | 06:58 PM
hawg50's Avatar
hawg50
try pushing your starter button before you turn the switch on,thats how i do mine.it seems to work for me.
Old Mar 24, 2014 | 07:15 PM
Chiledog's Avatar
Chiledog
With the PC III on my '04 FXDLi it would fire instantly.
Old Mar 24, 2014 | 08:00 PM
cashout's Avatar
cashout
Originally Posted by Newfie4Life
Last summer swapped out my fuelPak and went with a power commander 5. It's very slow to start. Sometimes you can hit the run button, then quickly hit the start button (recommendation via other forums) and she'll start right up. But most of the time it takes a while even if I try this procedure. Remove the PCV and it'll start right up every time. I had Power Commander look at my map and it checked out ok. Bike has new starter and battery has been tested three times now. Charging system is good. and battery is on trickle charger when sitting for any length of time. Also getting spark through the whole starting process. It just seems like the injectors are not coming on consistently like they normally do without the PCV. I've heard a lot of threads on this same issue, just trying to see if there is something I'm missing. Not a big fan of throwing money away and have little patience when reliability becomes questionable.
I have the same issue. 2012 street glide PCV mapped by fuel moto, turns over 3-5 seconds before firing. I've tried different timing with ignition/starter engage and have never found and consistently.
