soft fairing lowers
Old Mar 24, 2014 | 09:40 PM
hardheaded's Avatar
hardheaded
Default soft fairing lowers
was thinking about buying a set of these and was wondering if anybody knew at what air temp. you should remove these things? directions don't say s**t.
Old Mar 24, 2014 | 09:43 PM
1Canuck's Avatar
1Canuck
after you buy them the note said above 50* do not use
Old Mar 24, 2014 | 09:46 PM
dan conner's Avatar
dan conner
harley says 50 degrees, so you have to figure they are being conservative...i take mine off at 60 degrees. if it is raining a lot, you can figure the water is doing some extra cooling to the motor and go higher than that.
Old Mar 24, 2014 | 10:29 PM
hardheaded's Avatar
hardheaded
wow fifty degrees! that's not worth a s**t. i thought maybe you could run then until 70*
Old Mar 24, 2014 | 10:37 PM
Hurricane19's Avatar
Hurricane19
Mine say 55
Old Mar 24, 2014 | 10:39 PM
Hurricane19
[QUOTE="Hurricane19;12487370"]Mine say 55. They work pretty well and I don't wear chaps. Above 55 you really don't need IMO.
slowrollin
Jun 16, 2015 10:40 AM
Twinrider
Nov 3, 2010 02:05 PM
Sandcrab
Mar 19, 2010 12:04 PM
Sincecrazy
Jun 1, 2008 08:25 PM
rider
Oct 21, 2007 11:03 AM
