True dual..?
Old Mar 28, 2014 | 05:16 AM
HDsportster99's Avatar
HDsportster99
Default True dual..?
Just bought my 2008 RKC with 7688 miles on it. I'm looking to upgrade to true dual, and give it a real mean sound. The question I got is, what really goes into this? I know after changing the exhaust pipes to true dual I'm goin to need a rejet.. But I've read that there's much more it. Can someone shed some light on this for me? Thanks
Old Mar 28, 2014 | 05:29 AM
Notgrownup's Avatar
Notgrownup
1st things first... You AIN't rejetting...You will reprogramming the fuel injection...You will either go to the dealer and get a factory download or buy a fuel management system like Fuelpak or Power commander that the dealer or Independent can dyno and tune for you. This is unless you 08 actually has a carburator on it.
Old Mar 28, 2014 | 05:37 AM
HDsportster99
No, I have fuel injection. So I could buy the exhaust and the slip ons, do it myself. & get it reprogrammed and I'll be set?
Old Mar 28, 2014 | 05:43 AM
Notgrownup's Avatar
Notgrownup
If you plan on doing more modifications in the future do yourself a favor and buy a fuel management system like Fuel Moto, you will have free maps for life.
Old Mar 28, 2014 | 05:46 AM
HDsportster99
All I really have set is true dual, & some 16" apes.
I love adding a little but keeping it someone stock.
I will look into that tho, appreciate it
Old Mar 28, 2014 | 06:50 AM
SafetyMan's Avatar
SafetyMan
Just changing pipes IMHO is not a wise decision.
May as well do the intake while you're there.
True Duals, Intake, and fuel management.
There are a myriad of systems out there, from those like the V&H FuelPak, which is a piggyback to those like the TTS, which is a flash tuner.
If you're anything like me, and like tinkering and learning... and feeling the pride that comes from a job well done, go get a TTS, a PowerVision or a SESPT and study and learn. It is really not hard.
For an '08, being a 2 year bastard, sometimes you can find a GREAT deal on pipes. My best friend picked up a set of BUB7's, headers, mufflers, end caps, heat shields, the whole ball for like $280 shipped. We split on a 2 bike TTS, so he was into that for $300, and $150 for his intake. I did his Vtuning, him being my best Brother, I wouldn't take a nickel for my services, so he had a full aftermarket Stage 1 that runs like a raped ape for under $750.
Old Mar 28, 2014 | 07:20 AM
BigWaterJim's Avatar
BigWaterJim
Changing just the exhaust does not require a re tune. Once you do the intake then you do. When you do the exhaust ,intake and re tune it's called a stage 1.You can do the exhaust and then at later date get a programmer then at another time get the intake and re tune. Up to you. I did it all at once. Power Commader V is easy to do by yourself. You download from their site and install programmer.
Old Mar 28, 2014 | 07:44 AM
HDsportster99
So, if I wanted to only do exhaust for now.
I could put true duals on and everything and not have to even worry about programming or anything until I mess with the air filter..?
Old Mar 28, 2014 | 07:59 AM
warking's Avatar
warking
just changing your headers now will not need a tune. def will need it when you add the a/c & the bike can breathe better. .... however she would run better if you gave it a tune now as they run to lean from the factory.
Old Mar 28, 2014 | 08:12 AM
HDsportster99
You guys are a lot of help. Thank you.
Just gotta figure out what to put on it
