Making a Road King look more Classic
I would like to give it more of a classic look and don't really care for the trim and light on the front fender.
Is the trim easily changed to the Classic type trim?
The tires are original so I will change them out also and probably add a solo seat.
I do like the hard bags
Hit me up with your suggestions.
In fact, I'm kind of disappointed the 2014 decided to eliminate that. But to answer your question; Yes, it can be changed easily.
a contributor to the crash which killed the fast and furious actor Paul Walker, was 9 year old tires...a type which should have been changed out at 4 years max.
they get hard and don't grip so well, so do that first.
Also, pull the seat and make sure the fender isn't damaged or scuffed up...if you want a solo, you gotta have a presentable fender
you have to define "Classic" for yourself.
here a pic of my original '53:
of note is that the "Classic" bikes- pre-80's, were/are much smaller than the current touring bike, above you may note that the V twin motor is the largest single component- the gas tanks are 14 litres total- so 1/2 the size of current tank.
the frame neck/ forks are different, wheelbase smaller, fenders smaller etc etc
mike
mike
the HydraGlide forks are pretty much the same as the forks now, rigid frame, the rear tire is usually run at about 30 psi.
the seat is mounted on a "pogo" stick. spring sets and pre-load is used to keep the pogo from either bottoming or topping out.
on a bike like this you can ride "on the edge" and often be under the legal limit
mike
Yes".....Tires first I don't want to be riding on rotton rubber
Good thought about pullin the seat
