HD-LAN (can bus)
Old Mar 30, 2014 | 03:18 PM
01XLH's Avatar
01XLH
Originally Posted by GlidingJoe
snip
Sorry, just realized his is a Rode King. Hmmmm I will look at that wiring for you
No problem, actually that is the post that brought me back to HDForums.com when I started looking into changing the rear lighting.
I was thrilled when I looked in the FSM and the FLHTCU, FLHR & FLHX had the same wiring.
My lights do work, but they operate as Turn & Brake, I only want Turn & Running.
On my 05 Glide, I didn't want all 3 (as provided by the MoCo's conversion kit), so I replaced the single filament sockets with dual filament, changed bulbs and ran the new contacts to the license plate bulb wire, piece of cake, won't be the case with the new bike.
If they can't reprogram the BCM, I'll just add the wiring and LEDS in the turn signal housings as running lights. The license plate is moved to the saddlebag guard rails and I'm building a small 6 white LED "light bar" that will mount to the license plate frame for illuminating the plate. The system will approximate the current of the plate filament, so it should work, if not I'll figure something else out.
And if it ever stops snowing around here I may actually start riding and forget all this ancillary stuff.
Old Mar 30, 2014 | 03:21 PM
01XLH's Avatar
01XLH
To the OP, sorry for slight diversion...
Here's what I have so far.
Old Mar 30, 2014 | 04:25 PM
UppercaseJC's Avatar
UppercaseJC
Originally Posted by iwillfixthem4u
It was the 2014 Rushmore
Are the Japanese bikes wired like this as well?
Old Mar 30, 2014 | 04:46 PM
gusotto's Avatar
gusotto
The more I know about the CAN-BUS system, the more I want to stay away.
Old Mar 30, 2014 | 04:48 PM
UppercaseJC
Why??
Old Mar 30, 2014 | 05:11 PM
Wild Card's Avatar
Wild Card
All vehicles have can bus system now. Cant work on your bike try working on a 1/4million dollar truck.
Old Mar 30, 2014 | 05:34 PM
gusotto's Avatar
gusotto
Originally Posted by UppercaseJC
Why??
Because I wouldn't be able to work on the electrical as I can on my '07.
The parts manager agreed that self-electrical work will limited.
HD labor will be needed.
Old Mar 30, 2014 | 07:49 PM
Wild Card's Avatar
Wild Card
the parts manager @ a HD Dealer told you that
Old Mar 30, 2014 | 09:20 PM
Deucedog's Avatar
Deucedog
DIY electrical work on a 15 Touring model will need to include a thorough understanding of the new BCM system before anyone starts cutting and splicing. I'll reiterate that I learned that some system errors can/will shut the bike down if the BCM thinks there's a big enough problem. That problem could be as simple as sticking the pointed probe of a test light thru the wire insulation.
Until the riding community gets up to speed on the new system I would advise caution.
Old Mar 31, 2014 | 04:07 AM
grbrown's Avatar
grbrown
Red face
That's nonsense! It simply means we owners will have to adapt, that's all. Most of the vehicle industry is using canbus now, as stated earlier, and the diy/custom industry has NOT ground to a halt! Harley will continue to sell us electrical add-ons with instructions, just like they always have.
