2012 Ultra Classic with just under 10k miles...the last 2 rides I've noticed that when I am in 5th gear at low RPM (2200-2500) and I twist the throttle hard, the clutch appears to slip....RPMs will go quickly to about 4000 then come back down and go normally with the acceleration. I doesn't do it in any other gear but 5th, and I've tried purposely to reproduce it in the other gears.
Any thoughts? Hopefully its just an adjustment issue. Thanks!
Mine got out of whack after changing bars and slipped in high gear like yours. I had my Indy change cables and it still slipped. Took it to the dealership to get some work done and had them adjust it. They covered it under warranty and solved the problem.
I would ask has it been adjusted previously? Mine was adjusted at first service around 1k. They totally hosed it. I do it myself now. 1/2 hour and 15.00. First, make sure it is adjusted correctly and change the primary fluid with a good quality primary oil. Second. Don't keep slipping it until then. If you know it ain't good, don't do it. Downshift if it stops the problem. Third. Ride safe!
I just recently had the 10k service done and the primary fluid was changed by my indy. Now that I think about it I hadn't noticed the problem until after that service. I'm not mechanical at all so my alternatives are to take it back to them and tell them the adjustment is off or take it to (god forbid) the dealer. I'm out of the factory warranty but have an ESP.
I do my own servicing but had my dealer do a "once over" on the bike before warranty expired. They changed the primary fluid and adjusted the clutch. Mine did what yours is doing. The tech didn't back out the adjusting nut on the clutch...it was a simple fix but goes to show you that they aren't always paying attention.
Take it back to the Indy and tell him it is slipping. May be an easy adjustment like previously said. That clutch adjustment is more accurate when all cooled down good.
Good point. They usually do it hot which makes it hard to adjust, or at least less accurate, at the basket.
When I am planning on doing a service, I remove the derby cover from my stone cold bike, do the clutch adjustment, then lightly re-install the derby cover. Then I start the bike, go for a short ride to warm all the oils, return and dump the oils. I was never patient enough to wait until the bike cooled completely to do a good clutch adjustment if I waited until after I dumped the oil.
