2010 street glide. 5,000 miles. bought it already hooked up with true duals from rhineheart. i know my way around bikes but being 21 im not too sure on this stage one ro how it works. can someone just break it down or somehow not only explain what it does but if i should order it or a specififc kind you reccomend. use to carbs): thanks!
Stage 1 is usually different exhaust, either complete or just slipons, and better air cleaner. Usually it will have a tuner as well, but can be argued that a tuner is not necessary.
since your bike is new to you, it may already have a stage one, if the air cleaner has the stock 'football" cover sealed to a plastic backing plate, yours is stock. if the back of the football cover is open, then you are set.
and some kind of tuning compensation has already been done for you.
When I did Stage one on my 2010 limited there was a hugh different but now I have a 2014 and wondering it stage one will make a different?
Hi Ken and welcome to HDF from the UK. We have a dedicated forum to the 'Rushmore' 2014 bikes, where you should find info on that. Just go to the top of this Touring forum index - for Platform 9 3/4!
if the air cleaner has the stock 'football" cover sealed to a plastic backing plate, yours is stock. if the back of the football cover is open, then you are set. and some kind of tuning compensation has already been done for you.
Mike
What I've learned is the combination of different exhaust and "unrestricted" air cleaner requires some type of fuel managements system. Last summer when I purchased my new Street Glide the dealer told me I could change the exhaust (slip-ons) and not change anything else...but as soon as I put on the Heavy Breather (in addition to the slips-ons) I had to add a fuel monitoring system. Hope that helps
A stage I lets more air pass throw the engine that is other wise is stock, your engine is just
an air pump. More air in and more air out makes more horse power, by using a less restrictive
air cleaner and exhaust system. That requires better fueling and timing to run at the engines
best. The money spent on a stage I is more then likely the best bang for the Money.
