Thanks for looking. I need to find out if the bars off a 2010 Street glide trike are the same as ones on an 07 SG. Its a long story why I need to know and I don't want to bore the hell out of people so I got right to the point. Thank you for helping.
FLHX/I/SE Street Glide / CVO 2006 - 2013 1" 7-1/2" 31" 12-1/2" 11-1/2" 2-1/2" x 4-1/2"
FLHXXX Street Glide Trike 2009 - 2011 1" 7-1/2" 31" 12-1/2" 11-1/2" 2-1/2" x 4-1/2" 55947-08
well, in looking at the part numbers, this is what i come up with:
2010 street glide trike: 55924-08
2007 street glide: 55924-97
right off the bat, i can say they are not exactly the same, the trike has throttle by wire, the 07 street glide does not. so there is going to be that difference right off the bat. but, otherwise, since they have the same first 5 of the part number, i would 'guess' that the specs (rise, pullback, center width) would be the same.
If you help us we can help you! Why do you ask? If you have access to both bikes put them alongside each other and swap between them both to size them up.
