alright guys i purchased a pro pipe for my 02 road king from an individual with no brackets or hardware, thinking i could just order them from vance and hines. well turns out the pipe is discontinued.......... so i cant order the brackets!!!
DOES ANYBODY HAVE THIS PIPE on a touring bike of about the same year model? or have the brackets i need? or can u send me a pic of your brackets so maybe ill have someone make them for me?
Did you try the stock bracket ? I had a 2001 FLHTC with an old ProPipe I got used without the bracket. If I remember I was able to make the stock bracket work with a spacer The pipes were a little higher then the bracket. I remember it was pretty easy.
so simple .....my bike didnt come with the stock bracket because it had custom aftermarket pipes on it........i will go to the stealership and see if it will work. thanks for the idea
johnnynitro
