Adjustable push rods
Old Apr 9, 2014 | 02:09 PM
mountain man's Avatar
mountain man
One other positive with adjustable, if want to change cams down the road it will be a lot easier. JMO
Old Apr 9, 2014 | 02:14 PM
12hdrk's Avatar
12hdrk
Get the adjustable ones. It will let you fine tune and compensate for variations in tolerances. And as others have said, if you are doing cams, it's better to have adjustable to allow for variations in base circle diameter. Cams are published with that info, but it's a no brainer with the adjustables.
Old Apr 9, 2014 | 02:29 PM
fwb35's Avatar
fwb35
Yes, I went with adjustable when I put my SE 204 cams in, as stated if you have to go in there again you wont have to pull the heads, also depending on mileage change the lifters, I put V-Thunder lifters in from Comp Cams, my bike is very quiet now compared to before the cams, it also leaves you adjustability.
Old Apr 9, 2014 | 02:46 PM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
personally I went with adjustable just cause I wanted to have the ability to adjust. Very nice for getting rid of the top end racket. that alone was worth it for me.
Old Apr 9, 2014 | 04:04 PM
Noble Jim's Avatar
Noble Jim
Default Adjustables?
Originally Posted by Joe What
asking for some feedback on this.. I'm doing a 95 upgrade and cams on my 04 RK. Since I had to remove the heads should i just use the stock pushrods or should I go with adjustable.. I already purchased them but could use the $160 elsewhere.. any insight.. Thanks
Anytime you can use stock non-adjustable pushrods, DO IT. Stay away from adjustables if you can. Experience is whispering.
Old Apr 9, 2014 | 06:25 PM
qtrracer's Avatar
qtrracer
If a guy can't adjust and tighten adjustable pushrods properly he has no business changing cams.
Old Apr 9, 2014 | 06:31 PM
12hdrk's Avatar
12hdrk
Ain't that the truth! If you bugger that, you should have not attempted it at all. One of the simpler procedures you can do.
Old Apr 10, 2014 | 08:44 AM
Joe What's Avatar
Joe What
Its not a matter if I can do it (done it a few times) question was should I reuse the original
pushrods if its ok and appky the money of the adjustable rods else where.
Old Apr 10, 2014 | 09:13 AM
12hdrk's Avatar
12hdrk
I'm sure. Not a hard job. My comment was based on another's response that said you should never use adjustable. I think it's money well spent, since it provides a lot of flexibility down the road and an opportunity to set the correct preload in the lifter.
The lark
2014-2024 Touring Models
Oct 7, 2018 08:06 AM
Relentless
Engine Mechanical Topics
29
Mar 12, 2016 07:06 PM
h-d wrencher
Feb 21, 2013 08:08 AM
DeneFXDWG
Exhaust System Topics
Nov 25, 2011 05:37 AM
tslonige
Jan 5, 2010 11:40 AM
