Volt Meter Reading
Old Apr 15, 2014 | 10:04 AM
Da Shadow's Avatar
Da Shadow
Default Volt Meter Reading
What is normal at idle? Mine reads a little over 12 VDC idling. When I rev it up close to 2k rpm and above it is well over 14VDC. The only reason I am wondering is it has been a little sluggish to turn over a few times recently. Not every time though. Its a 2011 Limited.
Old Apr 15, 2014 | 10:31 AM
fwb35's Avatar
fwb35
Thats normal, mine does the same thing, if you want a true reading take it with a meter from your battery tender lead, or from the battery if you dont have a battery tender lead.
Old Apr 15, 2014 | 10:41 AM
roadking2014's Avatar
roadking2014
with a VOM at the battery post or the battery tender lead as fwb35 said it should be no lower than 13 idle and no higher than 15 revved.
Old Apr 15, 2014 | 12:09 PM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
That sounds right.......I've read on this forum before.....you can't charge your battery in the winter by starting it and letting it idle for awhile. It doesn't achieve high enough charging voltage (14V) unless the engine achieves a certain RPM which is higher than idle. I have watched the volt meter while at a stop light and that's pretty much what I see. Maybe the battery is loosing some life and needs to be on a tender if the bikes not ridden for several days.
Old Apr 15, 2014 | 12:27 PM
Da Shadow's Avatar
Da Shadow
Thanks Guys
Old Apr 15, 2014 | 09:31 PM
slapshot12's Avatar
slapshot12
Mine reads the around same thing. The slow turn over was the first sign I had when my battery was going. A new battery solved that, she fires right up now.
The electrical systems on motorcycles and outboards motors are not great for recharging a low battery. They are designed as a maintaining system, not a true recharging system. I keep both my bike and boat on battery tenders all the time.
Old Apr 15, 2014 | 11:24 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Agreed.
A slow crank over is a good, early sign of a week battery as soon as possible.
I have a '13 CVO Ultra that I purchased in October '12 and I'm going to rotate it into another bike and order a new one from Battery Mart before the riding season starts.
Daddywags
Electrical/Lighting/Alarm
Aug 28, 2018 05:32 AM
mgmmgm
Aug 3, 2015 05:52 PM
WOLFE1584
Mar 12, 2013 01:13 PM
hockey8787
Jun 8, 2012 09:10 PM
Qball
Apr 24, 2007 10:03 AM
