Tire cupping
Old Apr 16, 2014 | 08:43 PM
Def Mute's Avatar
Def Mute
If I'm not mistaken...
The Dunlop front D407 had a mfg defect which resulted in cupping. That was a few years ago. I believe they have resolved that issue? MoCo wouldn't acknowledge the problem unless you brought it in and complained. Then the tire was replaced, free of charge.
Apples and oranges, I know, but cupping on auto tires is commonly known to be caused by low pressure. Works the same with two wheeled vehicles, I believe. I know for a fact, that when I wasn't paying attention to tire pressures, my rear tire developed cupping. Haven't had a problem since I began checking before each ride, or at least once a week if I was riding often.
Old Apr 17, 2014 | 12:33 AM
ke5rbd's Avatar
ke5rbd
I have 2010 FLHTK and got 11000 out of 1st rear tire and it cupped severely. Got more diligent with keeping the air pressure up and got 16000 out of the next rear and could have gone further, but was cupped pretty bad. The first front tire got 19000 and it was not cupped at all. Got set of Dunlop Elite on it now. Won't get a chance to check mileage as upgrading to 2014 TK tomorrow.
Old Apr 17, 2014 | 12:21 PM
FlaHeatWave's Avatar
FlaHeatWave
The only bike that I have ever owned that scallops the rear tire is the '09 SERG with the factory Dunlops, which is our only option (size-load rating) at this time.
The '01 FXDWG2 and the '05 SEEG (also currently own) have always worn perfectly even (except the "Florida stripe" down the middle).
'Have always been **** about tires on everything that I have ever owned.
'Have been running 40 psi in the rear of the '09 SERG, maybe I'll try 41-42 psi?
'Not buying the "they all do that" from the articles (links) of this thread...
Old Apr 17, 2014 | 03:42 PM
Jerry1834's Avatar
Jerry1834
I have had cupping issues on all the rears since 2009…..would get 11 to 14k and they would be noisy going into the turns…I complained to Dunlop and HD with no help. Nature of the tire and always checked PSI…...
Old Apr 17, 2014 | 04:28 PM
FlaHeatWave
I think that a lot of us are hoping that somebody (even Dunlop! fer cryin' out loud!) will come out with an alternative in the 18/19 sizes...
Old Apr 17, 2014 | 07:53 PM
roadrunner10's Avatar
roadrunner10
I have ruined a tire on a road trip from heavy load and under pressured. Two up and 30psi on the rear. Didn't look low to the eye but I'm guessing I overheated the casing.
I considered it a valuable lesson and since then I'm always monitoring my pressure. I have excellent suspension front and back and still I get tire cupping on the rear at about half way thru the tread life. (Dunlop American Elites and stock HD Dunlops) Last three tires.
I havent tried the Continentals.
This is the main reason I'm tempted to TRY a car tire on the back. Lots of riders swear by them.
Until I can actually TALK to someone that has tried a car tire I'll probably try the continentals next...
Old Apr 17, 2014 | 08:52 PM
BLMC's Avatar
BLMC
I had a problem with cupping on several sets of Dunlops. I am now on my second set of Michelin Commanders with no cupping problems.
Old Apr 17, 2014 | 09:44 PM
glock221's Avatar
glock221
Originally Posted by Hogpro
My stock rear cupped really bad. I went with a different brand (Micheline Commander II) to replace it and it is night and day with ride quality compared to stock.
Can I get the Commander 2 in a 200/55/17 for my FLHX? I am worried about the load rating.
Old Apr 18, 2014 | 04:06 PM
FlaHeatWave
'Met some Vehicle Dynamics Engineers at a Roadhouse in Kingman AZ (H-D & Chrysler share the same Proving Grounds a little South of there), last October, showed them the scalloping on the rear tire of the '09 SERG, after some deliberation (I had already told them that the alignment, balance, pressure is / always spot on) The Engineers bought us a couple more rounds, and suggested;
"Firm up the Left (Drive) side of the Bike, because that's where the greatest forces (torque deflection) occur."
We installed the GlidePro Kit in the '09 (has H-D Premium f/r already), but haven't had a chance to put any miles yet, as the 117 / DD7 Build is just hitting the road tomorrow. The tire (already scalloping) has about 3k on it, so I don't know how reliable my observations will be until we start with a new tire...
Another theory is that Dunlop has yet to figure out the Transition Compound(s) (This one has my vote)
Old Apr 18, 2014 | 07:41 PM
Rdgray's Avatar
Rdgray
Originally Posted by bagman1
Besides tire psi being some of the issue, I believe the forks and rear shocks play a bigger issue causing cupping. Usually cupping on an auto is from weak shocks and the tires dribble up and down going down the road, the same theory holds true with the rebound/compression of the forks and shocks.
How many HD's have precise suspension adjustments? Not too many, throw in the fact that majority of folks dont adjust their air properly and it goes down hill from there. FWIW, once a tire wear pattern is started (even when you cant see it starting) it only accellerates wear and theres nothing one can do to stop it.
I believe you have the right idea. I use to work a lot with auto suspensions.
