What is likely to be causing front end "wobble?"
Old Sep 4, 2014 | 09:30 PM
  #31
skratch's Avatar
skratch
Originally Posted by monkey sammich
Did an impromptu fallaway test today, and the result was that the front end turns a total of 4 times before returning to center. I'm guessing that means the steering head needs to be tightened.
no, that is in spec. granted on the high side of spec, but for an ultra classic, 5 is the max.
Old Sep 5, 2014 | 02:53 PM
  #32
jefla's Avatar
jefla
[QUOTE=SteveMKentucky;12608318]You said that you put fresh air in the tires. If you left any old air in it could cause an unbalance (just kidding). QUOTE]
Yeah, made me laugh.
Old Sep 5, 2014 | 03:45 PM
  #33
SolDoctor's Avatar
SolDoctor
This just happened to my 2013 FLHX and it turned out to be warped front rotors.
Old Sep 5, 2014 | 10:31 PM
  #34
cmass's Avatar
cmass
Had this happen last year on my heritage, right at 30-35 mph. Pulled into Harley and they tightened the steering bearing, no longer a problem. It could be the tire, but that would be more gradual... More then likely, bearing just needs to be tightened....
Old Sep 13, 2014 | 04:51 PM
  #35
K Wyle's Avatar
K Wyle
Cool steering head bearings
So at 35 I could feel a slight wobble. At 80 on the highway going right on a long sweeper made me grip my seat! Problem was that my steering head bearings where out of spec/too tight.
Originally Posted by SteveMKentucky
Vibration or wobble in a motorcycle front end can originate from a couple of causes. The most common problem is usually the tires. You said that you put fresh air in the tires. If you left any old air in it could cause an unbalance (just kidding). Honestly the most common problem is the tire being out of balance. If the tires are fine the problem is likely the steering head bearings. Loose bearings will usually cause the front end to 'wander.' Tight will cause the bike to resist entering turns. I'd check the tires first, then move to the steering head.
Rhettm
2014-2024 Touring Models
24
Jul 31, 2021 07:03 AM
StuCliffy
13
Oct 26, 2018 12:57 PM
harleyheaven
Aug 29, 2013 08:08 PM
2106HD
Nov 28, 2010 01:39 PM
MJR
Jul 3, 2008 12:22 PM
