Progressive 412's std vs HD vs changing shock oil
Old Apr 27, 2014 | 06:45 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Can't say how well progressive or ohlin shocks work on a harley. Can say that my stock 13" shocks with 15 oil do not bottom out when I'm banging down dirt tracks with adv type bikes, and rides very plush without any added air pressure on the asphalt.
Cost me two ~$20 for two different jugs of oil to get it right. That's several hundred less than good quality replacement shocks. The results are good enough that I'm no longer window shopping replacement shocks.
Old Apr 27, 2014 | 07:09 PM
Bagger_Vance's Avatar
Bagger_Vance
Originally Posted by Veekness
It improved my ride well enough that it slid the shock replacement WAY down the list! Very pleased...
That's kind of what I was thinking for many people. I like my new 412s very much but probably going to put them up for sale even though I just put them on (they only have 300 miles on them). I'm going to go with a 13" or 13.5" for 2 up riding on long trips. It takes a whole 15 minutes to swap them out so it's no big deal.
EDIT: Oh, and changing the oil out in the shocks takes 10 minutes each if you have the Harbor Freight vacuum brake bleeder and correct fitting to put into the shock. That bleeder is a great value and I've used it a dozen times or so.
Old Apr 27, 2014 | 07:35 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Originally Posted by InvertedB
This may be a dumb question, but can the rear shock oil be done successfully if you don't have a press?
Yes sir you can turn the shock upside down and push on the shock to pump it out...or as I have found out now....use the Harbor Freight brake bleeder and suck the old oil out.
As posted....this mod works soooo well that I've not considered selling my Street Glide as it rides soooo much better and my back doesnt hurt at all. $10 worth of Bel Ray and the world is a smooth place. The rest of you doubters....keep paying the stealer for that incorrect information, after all they need the money, lol.
Old Apr 27, 2014 | 08:14 PM
steelerdude1's Avatar
steelerdude1
Do you know what fitting I will need, and where I can get one?
Old Apr 27, 2014 | 08:35 PM
Bagger_Vance
I had one in an air hose kit but I think it's a 1/8 NPT barbed fitting. Take off one of the stock shock fitting to the hardware store and double check. Probably in the plumbing section.
Old Apr 27, 2014 | 09:15 PM
foxtrapper's Avatar
foxtrapper
The vacuum pump kit will come with the fitting you will need. Just remove the brass bit the air line plugs into on the shock. Stick the tapered hose plug into it. It'll hold well enough to do the job.
Old Apr 27, 2014 | 09:38 PM
steelerdude1
Thanks for the info!!! I have the HF pump kit, but not sure if I still have all of the fitting. They are cheap enough to just go buy another one?. Can this be done with the shocks left on the bike, or will I need to take them off and turn them upside down?
Old Apr 27, 2014 | 10:06 PM
Bagger_Vance
The fitting did not come with my HF vacuum pump either. You might be able to do it on the bike somehow but I don't know the procedure. It only takes a couple minutes to take them off if you have a jack and will make your life a lot easier. If no jack then do one side at a time. Here is the procedure:
-Release all air pressure from shock
-Take shock off and put in your vice with fitting at the bottom
-Remove stock fitting and put in barbed
-Connect tubing to fitting
-Use the inline cup that came with the pump
-Hold cup below the shock fitting level
-Pump to create vacuum to fill up the cup with old fluid
-Release pressure
-Dump old fluid into a container you can measure
-Repeat drawing out old fluid until nothing comes out
-Turn shock right side up
-Measure the amount to put back in
-Fill up the cup with clean fluid
-Pump it up to create vacuum
-Turn the cup upside down and hold above the shock height
-Release pressure to draw new fluid into the shock
-Repeat until measured amount of good fluid is all in the shock
-Put stock fitting back in and reinstall
Old Apr 28, 2014 | 07:29 AM
foxtrapper's Avatar
foxtrapper
You need to invert the shocks to get the oil out. It won't work with the shocks mounted on the bike.
Old Apr 28, 2014 | 07:33 AM
Veekness's Avatar
Veekness
Any mom 'n' pop auto parts store with knowledgeable people and Edelman fittings can help you out...1/8" NPT X 3/8" barbed hose fitting will get it done. I had one in my parts stock.
