Andrews 48s are in
Old Apr 24, 2014 | 12:11 PM
jrdfatboy's Avatar
jrdfatboy
Default Andrews 48s are in
Well boys, the Andrews 48s are in and I am pretty happy with the numbers. I just need the weather to cooperate and get some time off work to get on it for the most important test. The torque ended up at 113.73 ft lbs which was what I really wanted for my riding style. This should wake my 2012 fugly ultra up a bit. I'll let you know.
Old Apr 24, 2014 | 12:16 PM
2010 ultra man's Avatar
2010 ultra man
Sounds like fun! Post how it turns out.
Old Apr 24, 2014 | 12:32 PM
jrdfatboy's Avatar
jrdfatboy
2010 ultra,143 lbs of torque! How do you keep a rear tire on it.
Old Apr 24, 2014 | 12:55 PM
0ldhippie's Avatar
0ldhippie
Glad ya are happy! Would love to see the torque curve??
Old Apr 24, 2014 | 05:28 PM
X Iron Butt's Avatar
X Iron Butt
I just did my 48's. Don't have the dyno yet. What tuner are you using? What else have you modified?
Old Apr 24, 2014 | 07:31 PM
jrdfatboy's Avatar
jrdfatboy
I am trying to rotate the dyno sheet. Anyway, I have the fuel moto 2:1:2 headpipe, Roland Sands Venturi air cleaner Vance& Hines slip ons, sert. I will post the Dino sheet in a few. Thanks
Old Apr 24, 2014 | 07:58 PM
jrdfatboy's Avatar
jrdfatboy
I got it, here you go.
Old Apr 25, 2014 | 03:20 AM
ybnorml's Avatar
ybnorml
Did you need compression releases with this install ??
Will be interested to hear your report once you have put a few miles on...
as I'm debating between the Andrews 48h and S&S 551 easy starts.
Old Apr 25, 2014 | 04:42 AM
jrdfatboy's Avatar
jrdfatboy
I didn't get compression releases, if fact it was never even brought up. My bike is stock other than what I have listed. I am really excited to take it out for a ride. Like I said earlier the 2014 ultra rental was very noticeable with the new cams installed, I hope the 48s are even better in my fugly. I will let you know my thoughts as soon as the weather breaks. Thanks for reading.
Old Apr 25, 2014 | 07:32 AM
firefighter156's Avatar
firefighter156
ACR's wouldn't be needed. Compression not an issue.
