Lugging In 1st Starting Out
Old Apr 26, 2014 | 09:24 PM
Brian58's Avatar
Brian58
Originally Posted by hdoilcan
Thanks for the tip but seeing they're are a few of us with the same issue on new 14 models I don't think its a thing of knowing how to throttle out of first gear. This is my 6th Harley and the only one that I'v had with this issue so I'm gonna guess its the bike and not my riding skills.
so let me get this straight you bought a brand new RK, did you not take this 20K + motorcycle out for a test ride and if you did WHY did you buy it just to bitch about it if i made that big of a mistake I'd be quite about it.
Old Apr 26, 2014 | 09:47 PM
hdoilcan's Avatar
hdoilcan
Where am I bitching?? I'm was asking a legitimate question to an issue I haven't experienced on prior bikes . I'm very happy with my purchase. Just because something is new doesn't mean it can't have an issue..... As posted, other ppl are experiencing the same thing.
As far as test riding?? Weather was nasty, bike was new, the new RK has good reviews, I know how a RK ride as I was trading in a RKC. Didn't really feal like I needed to test ride it as I knew it was what I wanted.
Old Apr 26, 2014 | 10:02 PM
agedwards63's Avatar
agedwards63
Uhmmm throttle by wire IS different than a cable guys... just a small learning curve
Old Apr 26, 2014 | 10:05 PM
dgreen1069's Avatar
dgreen1069
Very true, but I ride a 2011 and a 2014 regularly. In my opinion, the 2014 seems like it's geared a bit taller. Maybe it's the cam or something else, but there is a noticeable difference.
Old Apr 26, 2014 | 10:24 PM
sixguns's Avatar
sixguns
This 2014 103" does take a little more slip than my '13 103" did, so there is something that has changed. I never thought this was a problem, just something to adapt to,not an issue. Although weird, the touring bike has a lower 1st gear ratio, perhaps its the cam profile?
Old Apr 26, 2014 | 10:30 PM
btsom's Avatar
btsom
I wonder if it will turn out that the first few degrees of twist grip rotation doesn't open the throttle plate as far on the new ones as it does on the older ones in an attempt to make low speed, low gear throttleing a bit easier/smoother.
Old Apr 26, 2014 | 10:36 PM
agedwards63
Perhaps its all tied in with the hydraulic clutch, I know the cam is different this year I will be test riding a Limited soon I will check this all out
Old Apr 26, 2014 | 10:40 PM
sixguns's Avatar
sixguns
Originally Posted by stro1965
There is no adjustment on your '14 hydraulic clutch.
There were no hydraulic clutches left for the '14 Road Kings, so they got cables. I adjusted mine today,will see if it acts different.
Old Apr 26, 2014 | 10:42 PM
stro1965's Avatar
stro1965
Ahhh, my bad, I assumed it was the entire touring line.
Old Apr 26, 2014 | 10:49 PM
texaswiz's Avatar
texaswiz
No kidding, try twisting that grip in your right hand when you are taking off from a start. I am guessing that will help a lot. On mine, I twist it counter clockwise (or toward me) when starting out if I want to accelerate. When I want to slow down I twist it counterclockwise. Works all the time.
