Lugging In 1st Starting Out
Old Apr 27, 2014 | 05:30 AM
  #31
Rdgray's Avatar
Rdgray
Originally Posted by texaswiz
No kidding, try twisting that grip in your right hand when you are taking off from a start. I am guessing that will help a lot. On mine, I twist it counter clockwise (or toward me) when starting out if I want to accelerate. When I want to slow down I twist it counterclockwise. Works all the time.
That bike would confuse me, counterclockwise to accelerate or decelerate.
Old Apr 27, 2014 | 05:48 AM
  #32
IUOE ROB's Avatar
IUOE ROB
Originally Posted by hdoilcan
Where am I bitching?? I'm was asking a legitimate question to an issue I haven't experienced on prior bikes . I'm very happy with my purchase. Just because something is new doesn't mean it can't have an issue..... As posted, other ppl are experiencing the same thing.
As far as test riding?? Weather was nasty, bike was new, the new RK has good reviews, I know how a RK ride as I was trading in a RKC. Didn't really feal like I needed to test ride it as I knew it was what I wanted.
Brian (all 11 posts of him) and some others are the reason you post these questions in the Rushmore section, lots of jealous not-very-willing-to-help folks over here.
Old Apr 27, 2014 | 05:57 AM
  #33
hapbob's Avatar
hapbob
Default Yea
Kinda glad to hear this...I have same effects with 2014 Trike...I thought it was the trike since it's my first trike but it sounds like it's combo clutch/engine configuration. I just have to give more throttle and its fine.
Sorry if this should be in the Rushmore section....no no the Trike Section. I by far find the best advice and information in the plain old Touring section. I guess because I was there before my Rushmore or my Trike.
Hap
Old Apr 27, 2014 | 06:51 AM
  #34
IMKMA's Avatar
IMKMA
I have a 2014 road king and haven't noticed this problem but I came off a 2011 FXDC which had a cable throttle so my prior experience is completely different. I have found that when going over bumps especially a series of bumps close together I am jerking the throttle. It seems too sensitive too me,but I'll get used to it. I love everything else about this bike.
Old Apr 27, 2014 | 07:32 AM
  #35
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by btsom
I wonder if it will turn out that the first few degrees of twist grip rotation doesn't open the throttle plate as far on the new ones as it does on the older ones in an attempt to make low speed, low gear throttleing a bit easier/smoother.
I would suspect you are fairly close to the answer. A throttle by wire that simply directly translated potentiometer values to actuator locations (throttle grip position to throttle plate position) would not have this problem.
However, the throttle grip sensor sends information to a computer, and that computer decides what to do with it. That decision is likely the problem. Riders are finding themselves in a computer determined throttle position that results in low takeoff power.
The good news is that this can be corrected with a simple remapping. The bad news is I doubt it will be done by the manufacturer. After market may step in though.
Old Apr 27, 2014 | 08:05 AM
  #36
Freebee's Avatar
Freebee
After checking a few review / specification websites.
I noticed the transmission gear ratio specifications are identical for touring models since at least 2009.
TMW 2014 FLHR
TMW 2009 FLHR
I bought a 2009 (with Throttle By Wire) and did not notice or remember needing a higher launch RPM for slow take-offs.
My non-scientific conclusion:
1) The low rpm (sub 2,500) is slightly different with the taller cams installed in the 2014.
2) It's been 5 years and 85,000 miles, since I've had a new clutch.
Old Apr 27, 2014 | 08:12 AM
  #37
jeffreydsilver's Avatar
jeffreydsilver
Yah I've been trying to avoid riding in town because if it.
It only gets "worse" when riding 2 up. The bike wants to go so give it some gas and go! Don't baby it around. At slow speeds use the friction zone and rear brake.
Old Apr 27, 2014 | 08:15 AM
  #38
UppercaseJC's Avatar
UppercaseJC
Originally Posted by Brian58
If you don't know how to throttle out in first gear on your own bike you shouldn't be riding... as far as slip on's go why leave the cat on newer bikes and don't say it's the money you already put on all the trinkets that add up to a full exhaust system.
Man you got to be an expert fast.
Old Apr 27, 2014 | 08:19 AM
  #39
UppercaseJC
so let me get this straight you bought a brand new RK, did you not take this 20K + motorcycle out for a test ride and if you did WHY did you buy it just to bitch about it if i made that big of a mistake I'd be quite about it.
Brian may I suggest you try just saying nice things for a while.
Old Apr 27, 2014 | 09:36 AM
  #40
roadking2014's Avatar
roadking2014
hdoilcan, it kinda feels like the old dual fire waisted spark coiled bikes did when they were getting on the edge of needed the points adjusted....a lil hesitation.
You can try blipping the throttle a couple of times and then rolling on rather than a quick twist of the throttle when starting out.
