The bracket circled below is for the antennae relocation kit that goes on the left side ...I can't find it, but does anyone know if they make an identical bracket that goes on the right side?
76410-09 is right side cb antenna kit to mount on right side of touring bikes 09-13. The bracket mounts to saddlebag guard and not sold separate from the kit.
This is the bracket I have for the antennae relo mount for a AM/FM antennae...I like the look and it integrates well into the bike. Would like the same look for the right side. I don't understand why they wouldn't make the same bracket for the right side.
If mounting points on the bike are the same on both sides, taking the left side bracket to a fabricator or machine shop they should be able to create a mirror image of the bracket for the right side.
There is a bracket available for the right side. I don't have the part number but this winter I had said bracket on my bike. I think you can buy it separate. It comes in a kit for cb relocation for tour pak detach. Check with your parts dept at dealer.
Yes, there are mounting points on the right side. I'll look into the fabricator route.
They do, but it's a different bracket, not the same style as the left side.
Edit: They actually may according to the link posted dansflhti above...shows part # 76504-09 mounting on the right side.
