Tank Swap
Old Mar 28, 2007 | 12:48 PM
Hooper's Avatar
Hooper
Default Tank Swap
Will a gas tank off a fuel injected bike work on a carbureted bike? Thanks for your help.
Old Mar 28, 2007 | 12:54 PM
gunrunner's Avatar
gunrunner
Default RE: Tank Swap
It would be best to get the right tank, EFI tanks are made different, have different plumbing and set up for internal fuel pumps. Find the right tank, it will be much easier and better than jerry rigging a efi onto a carb bike.
Old Mar 28, 2007 | 04:06 PM
jbhawley's Avatar
jbhawley
it depends on the year model. 2004 and newer touring bikes use the same fuel tank. Pre-2004 bikes had a different tank for the EFI adn carb. Definately check w/ the dealer and the parts manual. If you look at the last two digits of the part number that represents the years. Say for example, the part number for a 07 ultra tnak is 30011-04 (not the actual number) then any tank from an 04 to 07 will work. In 04 HD made a more standard tank and modified the EFI to tank connections to go into one hole rather than two as was previous. This allowed the EFI bikes to use the same tank inlet hole as a carb bike and one fuel line.
Old Mar 28, 2007 | 06:27 PM
Johnny Law's Avatar
Johnny Law
Pingle makes an adapter, depends on the year for which one you will use.
http://www.pingelonline.com/conversion_kit.htm
http://www.pingelonline.com/magneti_...conversion.htm
Hope this helps
JL
Old Mar 28, 2007 | 06:53 PM
gunrunner's Avatar
gunrunner
I love learning new things, on further research it does look like a EFI tank from a 04-06 it will also fit the carbed bikes. Plenty of them on ebay for sale.
extremeshot
General Topics/Tech Tips
Jun 30, 2014 03:13 PM
TormentedH-D
May 15, 2014 03:13 AM
hopatro@gmail.com
Dec 31, 2011 11:33 AM
bv
Exhaust System Topics
11
Mar 3, 2008 12:59 AM
Canuck HD
Dec 31, 2006 08:01 PM
