tank swap
Old Dec 31, 2011 | 09:59 AM
hopatro@gmail.com's Avatar
hopatro@gmail.com
Stage III
Default tank swap
just replaced my 87 tank with 2010 tank now fuel wont flow to carbs
Old Dec 31, 2011 | 10:14 AM
HighLiner's Avatar
HighLiner
Did you take all the fuel injection stuff out of the tank?
Old Dec 31, 2011 | 10:18 AM
hopatro@gmail.com
Stage III
no can you tell me more
Old Dec 31, 2011 | 10:36 AM
speedwaysteve's Avatar
speedwaysteve
Hmm not sure if a newer fuel injection tank will work on a carb bike.i tried it on my softail that came both fi and carb ..i was told it had to be a carb style tank.
Old Dec 31, 2011 | 10:52 AM
hopatro@gmail.com
Stage III
can you tell me anymore
Old Dec 31, 2011 | 11:11 AM
rocknrod's Avatar
rocknrod
Wow, so you took a 2010 tank and put it on a bike that had a 1987 tank with carbs?
The 2010 tank has inside a fuel injection fuel pump, fuel filter electrical connections etc.
So your probably not going to get any fuel to the fuel outlet without everything being in order and operational inside. Other than a drip or two which wont support the carbs.
Also if you did have everything operational inside, the fuel pressure would be too great for the carbs anyway.
I don't have a break-down of the tank and the interior. I have it in the parts manual for my 08. But if you get someone to scan it they can post it for you. You can see all the parts inside the tank.
Old Dec 31, 2011 | 11:13 AM
Leftcoaster's Avatar
Leftcoaster
You're looking for info that should have been done before you did the swap. Guess I don't have to tell you how important research is before beginning any project.
Anyways, the difference between the two tanks is that the '10 tank is built for EFI and carries a fuel pump inside it and has no fuel petcock. The older carbureted bikes gravity feed to the carb through a petcock which is nothing more than a fuel shut-off valve.
What you need to do is remove the internal fuel pump and also the fitting that the fuel exits the tank through. Then fit a petcock to it and run a fuel line to your carb.
I don't know if this can be done. It depends whether or not the tank bung will accept a petcock and/or if there is a petcock available for this swap.
Old Dec 31, 2011 | 11:33 AM
pinecroft's Avatar
pinecroft
Check out this article in Baggers -- it details converting a FI tank to a Carb tank utilizing a Pingel conversion kit and also a Pingel petcock. paul
http://www.baggersmag.com/tech/0909_.../photo_13.html
bigmack
Mar 23, 2020 12:18 PM
extremeshot
General Topics/Tech Tips
Jun 30, 2014 03:13 PM
madcritter
Carburetor Related
Aug 13, 2009 10:59 PM
bv
Exhaust System Topics
11
Mar 3, 2008 12:59 AM
Hooper
Mar 28, 2007 06:53 PM
