09 Ultra CVO ??
Old Apr 29, 2014 | 08:33 PM
wheely's Avatar
wheely
Default 09 Ultra CVO ??
I'm thinking about buying a 2009 ultra CVO. Any pros or cons with the 09 bikes? I currently ride an 04 Ultra.
Old Apr 29, 2014 | 08:41 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
one of the better years imo,new frame 6 gallon tank,better suspension. 09 didn't have catalyst except cvo,so investigate if it still has it.
Old Apr 29, 2014 | 08:51 PM
bmaier's Avatar
bmaier
Great year, its got the new frame with the 180mm rear tire, improved suspension/swingarm, redesigned engine mounting. Also the much improved brembo brakes and 6 gallon tank that came in 2008
wheely's Avatar
wheely
I'll check on the catalyst. Guess removing it cools it down quite a bit??
Old Apr 29, 2014 | 09:07 PM
wheely's Avatar
wheely
Did the 09's have the 5th gear whine??
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Last year of the "Hand Built" CVOs by a two-four man team!
Check for any of the recalls or service bulletins regarding the 2009 model years.
Rear brake switch, tire recalls, fuel tank screw covers may come to mine.
YB
Old Apr 29, 2014 | 09:11 PM
bigdumbnoitall00
yes they have the 5th gear whine,its because of a stronger straight cut gear,and it quiets down down nicely around 10-20,000 miles.
Old Apr 29, 2014 | 09:14 PM
bigdumbnoitall00
2 problems i know about are primary bearing,not many from what i can tell and some early wheel bearing failures, but don't let those scare ya they aren't widespread problems.
Old Apr 29, 2014 | 09:16 PM
09 YELLOWBIRD
In all truth, the fifth gear cut is actually a stronger cut then the gear that replaced it in 2010.
To be honest I don't even hear mine whine anymore!
YB
wheely's Avatar
wheely
Good idea..... I'll checkout the bulletins. Thanks.
