Oil Level Question...
Old May 1, 2014 | 09:10 AM
goldie's Avatar
goldie
If you think its overfilled get a thin syringe type unit and sucks some oil out. I don't think a turkey baster will get in there. If its an Ultra it has no oil tank and just the crankcase. Worst case is dump the oil and change it. I wear my gloves when I check it hot. On a 500 mile day ride traveling I do like to check along the way. They need to idle for a couple of minutes so oil pump can pull oil out of top end to get accurate reading. 15 minutes isn't enough time to get "hot" unless its really warm out out........goldie
Old May 1, 2014 | 09:18 AM
TUCCI's Avatar
TUCCI
I also found very little diff between hot or cold oil checks on my FLH and FXDC 96" motors. As long as it doesnt go over the full mark dont sweat it.
Old May 1, 2014 | 11:02 AM
03snake's Avatar
03snake
'13 SG. Checking cold in the morning it was 1/2 way up the stick. After a 2 hour ride in hot weather and following the manual and allowing it to idle for 1-2 minutes on the jiffy stand (to scavenge the sump oil back to the tank) it read 1/2 way up the stick. Zero difference between cold and hot for me on multiple cold/hot checks. I only fill to 1/2 way up because when I filled to the full mark hot and then checked it cold it was still full. This led to venting into the air filter. 1/2 way up eliminates almost all of that for me.
Old May 1, 2014 | 11:26 AM
rbferg's Avatar
rbferg
As long as oil level is not above the full mark when hot, don't sweat it. If it is, a turkey baster will work just fine (I've used one once or twice) to remove a little oil. Cold check for mine is half way between the marks on dipstick. Hot check will usually be just a little closer to the full mark.
Old May 1, 2014 | 11:46 AM
UltraClassicElectraGlide's Avatar
Originally Posted by hd_rolling
I could be wrong with my thinking but the Harley oil level stick is designed for normal dyno oil, which expands and rises more when hot compared to a synthetic oil. OP are you using dyno oil or synthetic?
Running dino oil. Checked it again this morning 'cold' and it's at the same level as late last night, about two bubbles lower than the 'hot' full mark.
I take this as being too full, but if I ride it and it only goes to the 'hot' full mark, is it really overfilled?
Seems pretty simple, I just don't understand the discrepancy of the readings from 'cold' to 'hot'. According to the manuals if the 'cold' reading is in the normal range, then the implication is that when hot, it should be near that mark, but it didn't. Then, once topped off 'hot', the oil should go back down to the normal range of 'cold', but it didn't do that either.
Should I rider the bike as-is and then check the 'hot' and if it's no higher than the 'hot' full mark, leave it alone? Or do you guys think that doesn't matter, that it's more important to get it back down to the middle of the dipstick when 'cold'?
Old May 1, 2014 | 11:57 AM
EasTexUltra12's Avatar
EasTexUltra12
No way I'm going to be futzing around checking the oil on a hot air cooled motor. If it's halfway up the stick when cold, it's good.
Old May 1, 2014 | 12:00 PM
rbferg's Avatar
rbferg
It's fine, just leave it alone. If you notice oil dripping out of the air cleaner take a little out.
Old May 1, 2014 | 02:15 PM
NoCoLoco's Avatar
NoCoLoco
I think you're looking too closely at the cold check, it's just supposed to give you a general idea of how much oil is in there before starting it up. Follow the "HOT" check procedure in the owner's manual, that will be the "official" reading and the level you need to go by.
Old May 1, 2014 | 02:36 PM
yowflhtk's Avatar
yowflhtk
Let`s not over think this. If it`s between the marks, hot or cold, IT`S GOOD!!!!
Old May 1, 2014 | 02:48 PM
roadking2014's Avatar
roadking2014
between add and half way for cold check and between half way and full when hot...Wow, man! if this is freekin you out you need to check the alcohol level in your circulatory system and add a couple of 12 oz.
