No Fuel 03 Road Glide EFI
Old May 1, 2014 | 07:52 PM
MR Pink's Avatar
MR Pink
Stage III
Default No Fuel 03 Road Glide EFI
I have an 03 Road Glide with 11K on it. One day went to ride and would not start. To make a long story short found that there was no fuel being delivered. Fuel pump is not coming on. I pulled the pump jumped it with 12v and it runs fine. Replaced the hoses, filter and gasket reinstalled it. Just put a Cam Shaft Position Sensor in but still no fuel. I have checked all the fuses and have power to the pump for about 2 seconds when the ignition switch is first turned on then no power. I welcome your advise thanks for having me.
PS. Have a diagnostic code of 112 throttle roll off by using the engine light flash code retrieval method.
Thanks
Old May 3, 2014 | 11:06 AM
MR Pink's Avatar
MR Pink
Stage III
Could it be the Cam Shaft sensor?
Old May 3, 2014 | 08:27 PM
Melman's Avatar
Melman
Did you check the fuel pressure at the "petcock?" Could be the filter is plugged or the regulator
Old May 4, 2014 | 08:12 AM
MR Pink's Avatar
MR Pink
Stage III
I should have mentioned that I replaced the regulator when I replaced the hoses and filter.
Thanks
MAXWELL01RK
May 24, 2019 12:31 PM
Bryce05
EVO
26
Oct 23, 2018 04:25 PM
RedHeartbeat
Jul 20, 2012 10:22 PM
JR-Boston
Mar 24, 2012 04:33 PM
akpackfan
EVO
Jun 30, 2011 06:46 AM
