05 ECG, left hand turn signal works fine the right side has nothing, no green indicator,nothin . Bulbs, fuses everything good , run lights work all around.Turn module cause this ? Kinda stumped, Thanx for any help
If a bulb is bad, it will still have power to the signal light. That gives a steady turn signal indicator, not blinking. With no signal indicator, there has to be a loss of power some where. You'll need a digital volt/ohm meter, or test lamp to follow the power or lack of. Anything else is just a guess.
Type 5 synthetic blinker fluid only. Once yesterday screwin around with it got 4 ways to come on but still no indicator light on right side & like to never got them to go off . Strange
