Lower Fairing Question
Old May 6, 2014 | 12:21 AM
ROLLNTIGER's Avatar
ROLLNTIGER
Default Lower Fairing Question
Recently purchased some Mutazu Lower Fairings. Of course there are no installation instructions. Question... Do you need to remove the crash bar to mount the lowers? I have a 2010 Street Glide and for the life of me I can't get them on. I know I ordered the right one's I'm hopeing they sent the right one's
This is what I'm dealing with. I bought the bike used so the previous owner may have swapped the crash bar out. It just looks too close to the break pedal. There is no room. Maybe it's after market?
Old May 6, 2014 | 06:17 AM
steelerdude1's Avatar
steelerdude1
No you do not need to remove the crash bars. I had to Trim my matazu lowers to fit right, as they would not slide under the rear brake master cylinder.
Old May 6, 2014 | 07:25 AM
snip0721's Avatar
snip0721
I put a set on my 03 ultra, and didn't have to trim anything......snip.
Old May 6, 2014 | 08:19 AM
craigffb's Avatar
craigffb
I had to notch my right side lower too. Go to the local HD shop and see if you can find 09-13 touring bike with factory lowers and you will see where and how to notch the right lower to fit around the rear brake master.
Old May 6, 2014 | 09:08 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
The service manual is your friend.
Old May 6, 2014 | 10:10 AM
ROLLNTIGER's Avatar
ROLLNTIGER
added some photos so ya'll can see what I have on there now.
Old May 6, 2014 | 10:24 AM
steelerdude1
It does look close, I wonder If the PO moved the boards/controls forward with a kit.
Old May 6, 2014 | 10:33 AM
472viper's Avatar
472viper
So other than they don't fit, what do you think of the Mutazu lowers ?
Old May 6, 2014 | 10:49 AM
ROLLNTIGER's Avatar
ROLLNTIGER
Lol they are quality and I think that the Highway Bar is aftermarket and that's why it won't fit. If you look at the bends there is not much of an angle.
I have a call out the PO to see if he indeed changed the bar. If so I'll be in the market for a stock bar!
Old May 6, 2014 | 11:13 AM
jmpancoast's Avatar
jmpancoast
Not great pictures, but may give you an idea of the relationship between the stock bar, the chinese lowers, and the footboards:
Looks like quite a bit of difference in your bar and the OEM.
