bolting outer to inner primary 06 SG
Old May 6, 2014 | 08:08 PM
lkr0's Avatar
lkr0
Default bolting outer to inner primary 06 SG
lss - putting bike back together after new installing new primary tensioner shoe - one of the one bottom hole on the inner primary is striped - already had heli-coil - why can I just get a longer bolt and put a locking nut on the inner primary side? opinions please - thanks
Old May 6, 2014 | 08:39 PM
Def Mute's Avatar
Def Mute
It's your bike, do what you want...
But, is the outer surface of the inner primary even where that lock nut would be located? You would also probably benefit from using a little silicone sealer, like with the other bolts which have open threads, or in the transmission case. And, next time you take it off, remember what you did with that bolt. That brings up, if you sell it, are you going to tell the buyer what you did? I'd think re-doing the heli coil would be best...
Old May 6, 2014 | 08:59 PM
lkr0's Avatar
lkr0
yes, the outer surface of the inner-primary; not selling this one anytime too much $$ into it and it's one the last carb'ed bikes out there
Old May 6, 2014 | 10:13 PM
0ldhippie's Avatar
0ldhippie
Lots of inners out there that got swapped to chrome...
Old May 10, 2014 | 09:11 AM
Def Mute's Avatar
Def Mute
I was actually asking if the outer surface was even. Meaning, will the nut/washer seat on an even surface, where it won't cause the bolt to bend trying to conform to an uneven surface. It may also distort how the bolt 'pulls' on the primary case, like kind of pull to the side, if an uneven surface forced it sideways...
jurgie
Nov 12, 2024 09:28 PM
aviscomi
Dec 2, 2015 09:52 AM
Khshockey44
EVO
May 2, 2015 08:40 PM
hddave2
Jun 28, 2010 09:45 PM
billymons
May 31, 2009 10:52 PM
