Compensator Gone
Old May 9, 2014 | 10:45 PM
customsoftail200's Avatar
customsoftail200
Originally Posted by lp
Anyone notice any extra vibration in the footboards after your comp went bad?
I have a ton of drive line slack and huge vibration around 2200 rpm and idle/start off. Trying to figure out if the comp could be my problem before opening it all up.
Clutch feels good, no vibration there.
lp
Did you figure out your vibration? Mine has developed a bad floor board vibration also. I have the BDL comp in mine, so I'm assuming it's not that.
Old May 9, 2014 | 11:43 PM
texaswiz's Avatar
texaswiz
lp
I know that my 09 also has a lot of driveline slack. When I replaced a bearing on the final drive shaft, I was amazed at how much slop there was. I called one of the Harley mechanics and described it to him. He say "ya, there is a lot of slack in there...that is pretty much normal".
Old May 10, 2014 | 06:59 AM
lp's Avatar
lp
Not yet, but I'm about to tear into it. I'm not sold it's the comp because it doesn't seem to make any noise other than the normal startup bang which it's been doing since day one.
I hear ya. I was lucky to have owned a 10' for 35k miles and it didn't have the driveline slack this one just started demonstrating.
This one feels like, you know, a loose chain or something. Gas it, big pause, big bump then goes.
Then there is this vibration that is all over the place really. Bad at 2200-2500 rpm mostly. The engine is jumping around in the frame like it does at idle but at speed.
I've read a lot about vibration and comps over the last few days.
What I basically get about the vibration is that it could be exhaust touching the frame, a bad tune, something in the primary, crank runout, intake leak, spark, gas, air, or the presidents fault.
All over the place...
So today I'm going to start tearing into stuff and eliminating junk. Good times.
lp
maddghost
Aug 8, 2012 10:23 AM
maddghost
Aug 6, 2012 09:01 PM
dhog
Jun 2, 2012 06:35 AM
Reaper22
Jul 6, 2011 07:43 AM
Navy Mustang
Feb 12, 2011 10:26 AM
