Help Bikes dying?
Old May 9, 2014 | 01:08 PM
my67pnycar's Avatar
my67pnycar
Dunno if your in tank fuel pump is like mine or not but my guess is the fuel line in the tank has a hole in it and its sucking air or the filter is clogged. Just a thought.
Old May 9, 2014 | 01:13 PM
Nute's Avatar
Nute
If you hear sucking sound in tank 99% chance you have a hole in gas line. Try filling tank to full and see if that doesn t solve your problem until the gas in the tank gets low. Quite a common problem. Hoses in tanks rub against things until a hole wears through. When you replace the hose, change your gas filter as well.
Old May 9, 2014 | 01:40 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Why this is a good answer & is probably the problem & I hope you are running the stock plugs also this will cause problems to if you are not!
Old May 9, 2014 | 02:21 PM
jamess71's Avatar
jamess71
Hmm maybe. So is there a fuel line in the tank that goes from fuel pump to fuel? Sure does sound like this could no the problem.
Old May 9, 2014 | 04:13 PM
my67pnycar's Avatar
my67pnycar
When is the last time the fuel filter was changed?
Old May 12, 2014 | 10:36 AM
jamess71's Avatar
jamess71
Seems it is the fuel line in tank. When I filled it, it runs fine. Until the fuel level drops below the hole in the line again.
Samb3610
Electrical/Lighting/Alarm
Oct 7, 2015 04:01 PM
hogcowboy
Apr 14, 2014 12:00 PM
Histicku77
Jun 24, 2013 04:54 PM
longrider1956
Exhaust System Topics
May 30, 2010 04:09 AM
SURFOR Chop
Apr 15, 2009 10:03 PM
