Improved JRI shocks!!
Old May 9, 2014 | 09:46 AM
JCleary's Avatar
JCleary
Default Improved JRI shocks!!
I bought some 12" single-adjustable shocks from Howard. One of them had an issue, so I called JRI and they took care of me right away. Sent me a set of replacements, and I shipped the old ones back. There were some interesting changes to the new shocks. Just thought I'd share...
-Higher quality anodizing
-Better shock mount bushings, allowing for some flex
-Knurled adjuster with +/- markings
-Aluminum preload collar (hand adjustable as opposed to spanner wrench)
-Schrader valve inflation (for nitrogen only)
-Redesigned spring bucket
Pics:
Old May 9, 2014 | 01:41 PM
'05Train's Avatar
'05Train
Veeeeeery interesting.
Old May 9, 2014 | 01:48 PM
TWIN CAM 96's Avatar
TWIN CAM 96
What did you pay for these upgraded shocks if I my ask?
And is there only nitrogen in 1 shock it looks to me?
Old May 9, 2014 | 01:59 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
He posted pictures of old VS new.
Old May 9, 2014 | 02:09 PM
LQQK_OUT's Avatar
LQQK_OUT
Do you need to purchase direct from JRI to get the new version?
Old May 9, 2014 | 02:54 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Your stoked!
Prefect timing for your brand spanking shocks to screw up, and them to introduce their new shock
Bonus that you got the upgrade!!!
Give us a report when you get some miles on them bad azz shocks,
YB
Old May 14, 2014 | 11:37 AM
y2kflhr's Avatar
y2kflhr
damn those look even nicer than the old ones, I wonder if the internals changed at all?
Old May 14, 2014 | 12:29 PM
BlackSpecial's Avatar
BlackSpecial
Hope to install mine this weekend!
Old May 14, 2014 | 02:32 PM
FastHarley's Avatar
FastHarley
Former Sponsor
[quote=JCleary;12702725]I bought some 12" single-adjustable shocks from Howard. One of them had an issue, so I called JRI and they took care of me right away. Sent me a set of replacements, and I shipped the old ones back. There were some interesting changes to the new shocks. Just thought I'd share...
[quote]
Let me go over a few things with you.
<<< The red **** has a steel body that is coated and can not be anodized. It is coated. The new one has an aluminum body which can be anodized.
<<< Both have the exact same O-Rings inside of them, no difference between the two. The blue **** ones have a larger flange.
<<< Yes, I got tired of answering which way is right hand to make the shock stiffer.
<<< Both use the same threads on the shock body. The round aluminum ones have holes to put in the enclosed 1/4" steel rod. Either one you can hand tighten except when the spring is too tight.
<<< This will be removed once the membrane comes in because customers throughout the years start removing nitrogen redesigning the shock ride and cause the shocks to not work properly. They will also than try to fill up a shock with regular air where 10~15 bar (1 bar is 10 x the atmospheric pressure at sea level) or 10 bar = 14.7 pounds of pressure X 10 = 147 #.
<<< This is just a spring retainer, domed for looks.
* The piston size has been increased from 36mm to 1 1/2" diameter.
* The shaft has been made smaller and made rougher (microscopic depressions) to cut down on stiction on the seal head seals.
Old Aug 2, 2014 | 10:17 AM
JCleary's Avatar
JCleary
Thanks for the summary.
Any chance there will be spacers included in shock sets going forward? Sourcing them can be a PITA for the end-user.
