After discovering that my front wheel bearing had failed I have started to wonder about the rear wheel bearing. I did a search but didn't find any threads about rear wheel bearing failure on 2009 to current touring bikes.
What experiences have the forum members had with rear wheel bearing failure?
My 09 Ultra lost the right front bearing at 35000 miles while riding in the mountains. I called 4 Harley shops before I found a shop that had the bearings on the shelf. Makes you wonder how many bearings they are really changing. Little Rock HD had a set and is an awesome shop and I highly recommend them. When I got back home I bought a set for the rear and changed them. They showed no wear at all once I cut them open for inspection. The rear has 4 and run in a straight line . The front have 2 and take a beating in the curves on these large heavy bikes. I will change all bearings from now on at tire change. Earlier than 09 bikes have wider bearings and I think we just got caught up in budget cut from 09 on. My 1984 FXRS has well over 100000 miles and cup and cone Timken bearings have only been changed once because I wanted to. JMO
Mine failed last fall.....I just had the the Pipes and dyno done....a couple of weeks later...I kept feeling some extra vibration in the floorboards....the service tech said it was from the tune and pipes....but then I noticed a slight wobble at low speeds when rear braking....kinda like a warped rotor.....took it in and sure enough bad bearing...bad enough,,,,it ate the hub in rear wheel....I had everything replaced....new wheel, bearings, rotor, pads....never felt or heard anything at higher speeds....
