Sensor error? Road King 1999
Old May 11, 2014 | 02:24 AM
-morten-'s Avatar
-morten-
Stage II
Default Sensor error? Road King 1999
Hi guys and girls.
I have a problem with my Road King 1999 with a MM injection system.
I start up an cold engine and run for between 15 to 30 minutes without any problems. Then a short stop for 30 to 60 minutes or so. I start up again and the bike runs normally for about 5 minutes, and then the problem starts, it looses power, malfunctiuns and barely run. It does not stop, but does not pick up speed.
I was thinking that this might be a sensor problem?, any idea on whitch sensor?
take care.
-morten-
Norway
Old May 11, 2014 | 07:28 AM
Hx3's Avatar
Hx3
How many miles on your bike? Have you changed the fuel filter? If not, I would start there and also replace the fuel lines inside the tank as they have been known to rub against the tank and develop small pin holes in them. Good luck!
Old Jun 18, 2014 | 01:15 PM
-morten-'s Avatar
-morten-
Stage II
hi,
i must say, that when i got this reply, i did not take any notice of it, as i was sure it was a sensor problem since trouble disapeared with just a flick of the switch (ignition switch that is). but after trying a lot of other sollutions i changed the fuel filter, and now everthing i working.
KUDOS
-morten-
bmur66
EVO
29
Jun 3, 2017 09:29 AM
Howitt
Nov 12, 2012 08:30 PM
Focker
Nov 1, 2010 02:52 PM
Beowolf
May 2, 2010 12:37 PM
Taterdog
Nov 12, 2007 11:21 AM
