Compensator Replacement
Old May 11, 2014 | 12:06 PM
SoFLJoe's Avatar
SoFLJoe
Default Compensator Replacement
I may have to replace the compensator on my 08 ultra. From people who have done this before, do I need to remove the inner primary cover? How long should it take to replace? Also, what is the current part number for the stock replacement? Thanks
Old May 11, 2014 | 12:16 PM
Freebee's Avatar
Freebee
Either remove the inner or grind the small ridge inside the housing . Tons of threads on this process including the homemade hub locking tool.
Old May 11, 2014 | 12:17 PM
mkguitar's Avatar
mkguitar
disconnect battery
drain fluid
remove outer primary cover
loosen chain adjuster
remove clutch ( hub nut is left hand thread) and comp. pull it out.
don't use air tools, be prepared to lock the primary drive with a block or rag
mike
Old May 11, 2014 | 12:26 PM
EasternSP's Avatar
EasternSP
Compensator nut is regular thread. Have some red locktite to reinstall it. If it doesn't move when ya try to take it off, apply heat to the nut to melt down the Red Locktite that is on it already.
Old May 11, 2014 | 12:47 PM
oakmossy's Avatar
oakmossy
check out youtube . Search under 'replace harley stator'. 'VTwinOnline' is a good channel. You will see how its done. Counter clockwise ( to remove) for crank bolt, clockwise ( to remove) for clutch bolt.
Steve On 3
Nov 8, 2020 04:48 PM
abate1
May 30, 2012 04:08 PM
96roadking
EVO
34
Feb 21, 2011 05:09 PM
neurostudy
Feb 8, 2007 04:38 PM
HDF Tech
Electrical/Lighting/Alarm
Aug 2, 2005 07:59 PM
