Compemsating Sprocket removal??
Old May 30, 2012 | 04:02 PM
abate1's Avatar
abate1
Default Compemsating Sprocket removal??
I have a 2007 Electra Glide Classic and am going to replace the comp sprocket, question is: Does the inner primary have to come off to do this I have been told on older models there was enough "wiggle" room to remove with just the outer cover but not on this one. Anyone have any experience with this?
Thanks
Old May 30, 2012 | 04:08 PM
mkguitar's Avatar
mkguitar
just the outer primary cover.
loosen the primary chain tensioner
you may well have to remove the clutch as well.
do NOT use air impact tools on the comp sprocket or the clutch nut ( left hand thread).
you can lock the primary with a piece of wood, rag or a jam tool as shown in the manual
a proper sized socket with a long bar, slipping a piece of pipe over the ratchet handle if need be
mike
HTNHARD's Avatar
HTNHARD
This helped me on my 08.
https://www.hdforums.com/forum/touri...it-w-pics.html
SoFLJoe
May 11, 2014 12:47 PM
rquest
Dec 1, 2012 03:25 PM
PDDGM
Mar 30, 2012 02:43 PM
1996Softail
Jan 6, 2008 09:48 AM
missouri traveler
Jun 24, 2007 01:08 PM
