engine cleaning
Old May 12, 2014 | 10:08 AM
pghreed's Avatar
pghreed
Default engine cleaning
cleaned engine on 2011 street glide, btw the HD Engine Brightening Cleaner is awesome...
to the question though - How can i safely polish the machined finish on the jugs?
Old May 12, 2014 | 11:55 AM
pghreed's Avatar
pghreed
what i meant to ask is how to polish the machined edges on the engine fins
Old May 12, 2014 | 02:06 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Aluminum polish or cleaner
Old May 12, 2014 | 02:09 PM
Pix's Avatar
Pix
And a dremel with a buffing wheel, on slow speed, with a piece of rubber tubing around the metal shaft of the tool.
Old May 12, 2014 | 02:18 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Non-scratch Scotch-Brite and soapy water using Dawn dish soap.
Old May 12, 2014 | 02:25 PM
jberg's Avatar
jberg
I would think polish of any kind would stain the black part and a polishing device would shred on the sharp edges. I would use a stiff brush during the washing process and live with the result.
Old May 12, 2014 | 03:00 PM
pghreed's Avatar
pghreed
thanks for the replies from all the members, once i commit to trying it, I'll post the before and after.
Old May 12, 2014 | 03:11 PM
shooter5074
Keep in mind that you will be scrubbing on aluminum. Start with the least caustic/abrasive products first, so that you don't make it worse.
Old May 12, 2014 | 03:21 PM
NELS's Avatar
NELS
I use Scotch Brite pads . They come in different grades, depends on how bad they are.
Old May 12, 2014 | 03:57 PM
RollaMo's Avatar
RollaMo
+1
That edge is so narrow, it will be next to impossible to use any kind of polish and not get it on the "black" part of the fins.
You don't want to get any polish on the Black for sure.
This works very well!
You don't even need any "polish", just a quick brush with the pad.
