Clutch recommendations
Old May 14, 2014 | 12:52 PM
fwb35's Avatar
fwb35
Mine did the same after my S&S 97 inch big bore kit plus I am also running SE 204 cams, I adujusted it and put a stiffer clutch spring in, no problems or slipping anymore.
Old May 15, 2014 | 03:03 PM
60DRB's Avatar
60DRB
Picked up some type-F yesterday. I'll try to adjust and check this weekend. Thanks all.
Old May 18, 2014 | 05:55 AM
60DRB's Avatar
60DRB
Adjusted the clutch and drained & replaced the fluid. Nothing special on the drain plug but the fluid was like brown soup. One quick run up and down a 1/4 mile stretch seemed OK. I'll find out for sure over the next week of commuting.
Old May 18, 2014 | 06:03 AM
smitty901's Avatar
smitty901
Wet clutch it will turn brown meaningless
Old May 22, 2014 | 05:49 AM
60DRB's Avatar
60DRB
Well a couple hundred miles of mixed city & highway later... Clutch seems fine now. The simple adjustment seems to have done the trick. I do still occasionally hear a light metalic "clank" sound when the clutch engages, but no slipping at all.
Thanks all. Greg
Old May 22, 2014 | 06:01 AM
Notgrownup's Avatar
Notgrownup
.yes that is low miles to slip...unless you ride the clutch a lot ....84000 on my original....
Old Jul 26, 2014 | 05:23 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by '05Train
Barnett Kevlar +1 kit, 480# Evolution spring, and a Clutch Wiz. Great clamping force, and a reasonably easy pull at the lever.
The wiz is a waste of money.. Get the right spring to start.. I use stock plate count Barnetts.. A little cheaper..
Old Jul 26, 2014 | 06:36 PM
dochawken's Avatar
dochawken
My 2001 RK clutch has over 50K miles and has started slipping. I've got SE-204 cams and 95" kit. I'm looking for recommendations for clutch pack kits. I'm not a street racer, so I'm not really wanting to spend big dollars, just a good reliable replacement for a reasonable price. What brand and a source please.
Greg
Not many miles on a clutch, I had 97k on my 98 Softail and with proper adjustment it was fine...never any slipping.
Old Jul 28, 2014 | 04:28 AM
'05Train's Avatar
'05Train
Explain?
'Cause I've got less pull effort than stock and it's not slipping, even with my build.
Old Dec 2, 2014 | 03:38 PM
Max Headflow
Explain?
What are you running?
