Break in advice.
Old May 16, 2014 | 06:12 PM
BenRK05's Avatar
BenRK05
Default Break in advice.
I just got a call that my bike ready from the shop. I had to get the motor rebuilt after the a cam bearing failed and took out the motor. I need advice on the best way to break in the motor. The shop told me to only drive it in the evenings and don't get caught up in traffic. Not to keep the same rpms for long period of time. To do an oil change at 500, 1000 and 2000 miles. then i can ride it normal. What say the masses? Thanks guys.
Old May 16, 2014 | 06:23 PM
IUOE ROB's Avatar
IUOE ROB
If someone told you to redline the motor every shift and don't change the oil for 5,000 miles would you listen to them? Of course not...sounds like the shop gave you good advice and since they built it I'd listen to them...good luck with everything!
Old May 16, 2014 | 06:35 PM
2-Piece's Avatar
2-Piece
Some would say you should ride it hard to get the rings to seat right away. lots of WOT 2nd and 3rd gear pulls but be careful not to overheat.
That's how i did mine.
Old May 16, 2014 | 06:41 PM
desertwolf's Avatar
desertwolf
Old May 16, 2014 | 07:14 PM
btsom's Avatar
btsom
Here we go again. Do what the builder told you. He wants a good recommendation if anyone else you know needs his service. Following his instructions should provide the best results AND if anything craters, you can tell him you did just like he said and it still broke.
Old May 16, 2014 | 08:58 PM
lh4x4's Avatar
lh4x4
Read the last two issues of American Iron Magazine. It covered the entire spectrum of methods of breaking in a HD.
Best method is the one I used over many years. The basic fact the A.I.M. found is that a slow easy break in will produce a more longer lasting motor and one that runs stronger than the short fast break in that some do on a dyno or the street. The hard fast break in will result in a faster bike initially but in the long run the slow break in will out perform the fast and hard break in.
The articles were excellent in that they also identified the EVO and Pan break in methods and the reasons why the TC's are the strongest and best motors to come out of HD for longevity.
That is in spite of the arrested development of some riders that hang their hats on the older iron.
Old May 17, 2014 | 06:09 AM
grbrown's Avatar
grbrown
Cool
There are more ways to 'run in' a motor than to skin a cat! Ignore all other advice except what you were given by the shop who built it. Ride and enjoy. If you had got in the saddle early this morning, instead of in here, you could have got in the first 500 miles today, oil change in the morning and away again......
Old May 17, 2014 | 07:34 AM
1flhtk4me's Avatar
1flhtk4me
I don't agree with the "evenings" part.
Old May 17, 2014 | 09:44 AM
FenderGuy53's Avatar
FenderGuy53
Read this: Break-in Secrets
Old May 17, 2014 | 10:18 AM
Leftcoaster's Avatar
Leftcoaster
Just ride the thing, man. Don't over-rev it or lug it down and you're fine.
As far as all those oil changes go, I'd change out at 500 and then go right on to regular intervals.
