4 point docking install HELP!
Old May 22, 2014 | 08:33 AM
Rickierockit92's Avatar
Rickierockit92
Default 4 point docking install HELP!
07 street glide and have a tour pack with 4 point docking system and trying to install the docking system. i get the jist of how it will go but the antenna..... should i drill a hole in the bottom of the plastic piece the antenna goes through to relocate it? also... the way the docking system looks is how does it go through the piece ( the plastic piece in between the fender and the bags... its on both sides and is also the piece the antenna goes through) should i drill holes or just widen up what i have to make it work? anyone out there who has done this or knows what to do i would appreciate the help! thanks. ill post pics when i get home if that will make it easier for someone to understand whats going on.
Old May 22, 2014 | 09:24 AM
KSGLIDEGUY's Avatar
KSGLIDEGUY
There should be oval holes in the filler strips that the docking kit brackets go through. I just installed one on my 08. You will have to relocate your antenna to the tour pak or go with a inside the fairing antenna.
Old May 22, 2014 | 09:45 AM
Rickierockit92
I was checking the oval holes and it didint seem like they were long enough. i guess ill just have to take it apart and see. did yours fit in perfect or did you have to cut them or widen them out? 07 hopefully and shouldnt be smaller than the 08's is it?
Old May 22, 2014 | 09:58 AM
The Q's Avatar
The Q
You can also use an aftermarket Tour Pak mount that utilizes your backrest mounts and does away with the "hoops". I bought the Fat Baggers Inc. mount. There are many sources, but I found it the cheapest on eBay. Here is the link for the FBI mount for your year of Street Glide LINK
Old May 22, 2014 | 10:52 AM
KSGLIDEGUY's Avatar
KSGLIDEGUY
No mine fit fine without any problems. I would post a pic if I had one.
Old May 22, 2014 | 11:02 AM
2010 ultra man's Avatar
2010 ultra man
Default 4-piont docking
put a hidden antenna in the fairing and stash the antenna cord under the seat.
Old May 22, 2014 | 11:38 AM
Rickierockit92
how much do they usually run? im guessing its a harley product?
Old May 22, 2014 | 11:40 AM
Rickierockit92
i will for sure when i get home.
Old May 23, 2014 | 06:51 AM
2010 ultra man
There are other brands, but this works.
http://www.harley-davidson.com/store...08-76000513--1
kevbo
Feb 4, 2018 07:17 PM
chrskrngl
Jun 20, 2011 03:10 PM
lock55
Jul 30, 2009 03:16 AM
bigbean78
Nov 4, 2007 07:25 AM
ftlee20723
Aug 18, 2007 04:02 PM
