Going to be doing head gaskets
Old Mar 30, 2007 | 10:20 PM
twistedcherokee's Avatar
twistedcherokee
Default Going to be doing head gaskets
Any tips? 99 Ultra Classic with95 cu in. What kind of head gaskets work the best? Good idea to go with adjustable push rods? If so, what kind are the best? TIA
Toby
Old Mar 30, 2007 | 10:57 PM
dawg's Avatar
dawg
Default RE: Going to be doing head gaskets
Go with the cometic .030 head gaskets and you can get the SE adjustables and they will work fine.
Old Mar 30, 2007 | 10:59 PM
Retired_Ted's Avatar
Retired_Ted
Like Dawg said - adjustables are nice since you can play with the cam area without the removal of the top end.
Old Mar 30, 2007 | 11:12 PM
Gunney8's Avatar
Gunney8
Ditto to Dawg and Ted. Cometics will add some compression to your build as well and if the're the metal 3 layer type, they are bullet-proof. Would be good idea to add thoseadjustables whilst youhaveit torn down.
Old Apr 3, 2007 | 01:54 AM
twistedcherokee
So on the SE adjustable push rods do you need new tubes? Are they different? Where is the best place to pick up the parts I need? Do I need to take the heads to a machine shop and have them surfaced? Give me a 4wd and no problem with working on them, but I am new to working on Harley's.
Toby
Old Apr 3, 2007 | 02:12 AM
tireater's Avatar
tireater
What the first guy said...
Old Apr 6, 2007 | 10:41 PM
twistedcherokee
Well I ordered the Cometics gaskets at one of the cycle shops, they had the set but had to order the head gaskets for the 95's. They where going to overnight them so I would have them on Friday or Sat. I was going to put the bike back together on Sunday, the head gaskets did not come in and they said it would be Monday. Delema here, they said that they could get me the SE multilayer gaskets for Sat. Has anyone had problems with the SE head gaskets and should I wait until I get the Cometics or go together with the SE's. Thanks
Toby
Uncle Fuzzy
Engine Mechanical Topics
21
Aug 21, 2022 11:57 AM
PanHeadDav
Exhaust System Topics
Aug 7, 2011 12:30 PM
Surfit
13
Jun 15, 2010 09:33 AM
popstheoldman
Apr 26, 2009 09:26 PM
twistedcherokee
Mar 27, 2007 11:07 PM
