Dreaded Kury Peg Mount "D" Washer: Any Cures?
Old May 29, 2014 | 10:43 PM
FenderGuy53's Avatar
FenderGuy53
Originally Posted by dirtdobber
Are you using 1 or 2 D washers.
First step is to see why it is in a bind. Take the side of the washer/curved part or edge/ slide it between the fp and clevis. If there is some clearance the spring is too tight. I just hit em with a good hammer, won't hurt em, until I get the tension I ant. If it is too thick then pick up a few stainless steel flat washers if too thin put a slight bend in the washer using your vice. This is my cure,
Was only using the one D washer on each side - and both were ridiculously too tight. I did the hammer thing, but to no avail. I like your idea of the stainless steel flat washers. Thanks!
Originally Posted by skratch
i find that if you really torque down on the bolt holding the peg on, it will also induce a lot of resistance to the peg folding. use threadlocker, and don't tighten that bolt down to 100 ft/lbs and it should go up and down fairly easy.
Didn't think of that one, skratch. Great observation. Thanks!
No U Glider
2014-2024 Touring Models
Sep 12, 2017 07:13 AM
nathan-hd48
Mar 16, 2015 05:29 PM
bulldog82098
Oct 6, 2011 08:58 AM
RocketRocker
Feb 2, 2011 02:34 PM
schumacher
Apr 1, 2009 03:29 PM
